Hello,
I am making some Aluminum shapes - let just say that is like a small box 10x15" The tickness is 3/16 - 5052 Industrial AL. I can make it with a break but is painfull , is not exact always, and is very inconvenient at some bendings.
I can make a moulding out of mild steel - no problem. My only concern is that if I do it - when I will press down - the exterior side of the AL will scratch.
I have absolutely no ideea what should I use for the moulding material. It has to be very strong yet soft so it does not scratch my part
Again - this is an example - the complexity of the parts that I create is bigger than that and requires multiple mouldings.
I really appreciate your help -
Thank you
