585,991 active members*
4,725 visitors online*
    Mar 2008
    6
    DIY 3 Axis capable of 4A?
    Im looking around and i cant find a controller that supports Bipolar and 4A per phase that is a simple DIY project. Im not trying to reinvent the wheel .
    im hoping for something i can build at home but even a prebuilt one is fine as long as its not crazy expensive...
    Any input would be extremely helpful
    Thanks in advance
    Mar 2008
    6
    no one?
    http://www.geckodrive.com/
    i searched and searched for my setup when i used 4amp motors , there really aren't many reasonable options for cheap priced drivers , i bought geckos and am more than happy with the decision , they are by far the best bang for the buck
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
  1. Tube Bending Machine Capable of 2"x4" Rectangular Tubing
    By morribi in forum Bending, Forging, Extrusion...
    Last Post: 06-27-2010, 04:47 PM
  2. New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter
    By the__extreme in forum CNC Wood Router Project Log
    Last Post: 02-26-2007, 09:58 PM
  3. Is this Linear Slide capable of handling 100pounds
    By pinakbeth in forum Linear and Rotary Motion
    Last Post: 01-19-2007, 02:56 PM
  4. Assembly line capable milling machine
    By MrRage in forum Uncategorised MetalWorking Machines
    Last Post: 09-14-2005, 01:21 AM
  5. Which Cam Software Is The Most Capable?
    By wild01 in forum Uncategorised CAM Discussion
    Last Post: 07-18-2005, 10:32 PM
