585,700 active members*
3,317 visitors online*
Results 1 to 7 of 7
    Jan 2008
    575
    post processors
    do any of you guys use Mastercam X on an OSP control and if so, how hard was it to get it to post correctly? This is my first job where I had to edit my own processor and frankly I'm a little intimidated. I know the control very well, but not so much the software. I have been behind the post a little, and made a copy of it so as not to alter the original, but I guess I'm a little overwhelmed by the amount of data. Any help would be appreciated
    Jan 2008
    575
    oh yeah, I need to post to 5020L, a 7000 and an E100
    Feb 2008
    16
    If you have one for a OSP 5000 it will work for a 5020, a 7000, a E100, a U100, aP100 and a P200. As long as they are all the same style of machine.
    Aug 2007
    19
    What is wrong with the post you have now?
    Jan 2008
    575
    It does not support the C axis correctly on the turn centers. It outputs Radial values instead of values in degrees, and feeds per minute (which I am sure is due to my own inexperience and a minor parameter change) instead of degrees per minute.
    That said we just got maintenence and X3 so I am sure they can get me lined out.
    Thanks, Robert
    Aug 2007
    19
    Quote Originally Posted by littlerob View Post
    Thanks, Robert
    I have been through the same thing. I have a post for the lathe work, which does not support c axis. Then I have a separate post for the c-axis work that doesn't post out the lathework correctly. I use the both of them and paste the two programs together.
    I spent tons of time trying to modify posts so they would do what i wanted them to do. In the end i wasn't much better off then when i started. alot of things are easy to change in the control def. or in the post itself with switches.
    but when start trying to move things around it gets pretty tricky
    I always program c-axis work in IPM.
    I haven't had much luck with c-axis and mastercam. Or 4-axis and mastercam for that matter.
    Good luck with x3
    BTW insider secret - check out the emastercam.com forums
    the guys there are very helpful and will have an answer for any question you may have. Just don't ask for a post.
    Jan 2008
    575
    Quote Originally Posted by kazmir44 View Post
    Awesome thanks alot for the tip.
    X3 is really cool
    And trying to post for the C-axis combined the rest is getting frustrating, I have really appreciated Mastercams customer support so far, but I would like to be able to post a turn, drill, and live tool op, with one post processor.
  1. post processors?
    By john_t_h in forum Syil Products
    Last Post: 11-26-2018, 05:01 AM
  2. Post Processors for Fadal
    By sbarziza in forum CamWorks
    Last Post: 06-25-2007, 07:08 PM
  3. Mastercam post processors
    By premierpatterns in forum Bridgeport / Hardinge Mills
    Last Post: 11-24-2006, 01:19 PM
  4. V20 post processors
    By doug6949 in forum BobCad-Cam
    Last Post: 02-22-2005, 02:49 PM
  5. post processors
    By Turn Man in forum Uncategorised CAM Discussion
    Last Post: 05-30-2004, 07:13 PM
