586,000 active members*
5,133 visitors online*
IndustryArena Forum > MetalWorking Machines > OKK > emg ls problem MCV 460
Results 1 to 5 of 5
    May 2008
    15
    I Have a okk mcv 460,like the 500. i had the machine running the other day,was fine. Shut it down for some maintence, when started back up got the ready light, then after a few seconds got alarm 1008 oil cooling (head) & 1071 emg LS on. it is stuck in a state emg stop. Cooler seems ok, emg stop button is working. the local guy isn't real familair with the 5000c2 controls. Any help is appreciated.
    Apr 2008
    11
    You should have a EMG> release switch. Hold this up, & hit reset. Then in handle, move all axis off home pos. at least a 1\2 inch. If that wount work, check for a stuck limit switch. The screen may tell you what axis it is.
    May 2008
    15
    Thanks for the info, i had tried that. i got a hold of mitsubishi and found out it was a board in the control.
    Mar 2004
    47
    okk manuals
    I have a mch 450 and a pcv40. I have manuals for both. I am looking for a "parts" machine. What board do you need?
    Bob
    Robert Setree 502-452-9851
    Quote Originally Posted by Luslugger View Post
    Bob
    I need the parameter for pcv 40 with fanuc 18MB,
    Do you have it?
    Regards,
    Sting
  1. Please Help. Having problem with CNC driver/card problem.
    By todatop in forum Commercial CNC Wood Routers
    Last Post: 02-09-2018, 05:40 PM
  2. Having problem with CNC driver/card problem
    Last Post: 04-09-2014, 05:45 PM
  3. Tube problem or powersupply problem? Help you to check out
    By Melody-gweike in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-05-2012, 04:09 AM
  4. daewoo puma 12lb tape format problem/parameter problem
    By robb12877 in forum Daewoo/Doosan
    Last Post: 08-25-2011, 06:13 AM
  5. Replies: 5
    Last Post: 08-04-2010, 11:33 PM
