Is there a "deal" that will give me a estimated run time with master cam 9 based on the programmed feeds and speeds of the program? If so where is it? If not is there something out there that does?
Leroy
Leroy
Hi: In the main menu,NC utilities,setup sheet (operation tab, just click on the tool icon at the LH side). It uses your post (where you have correctly entered the toolchange time and rapid) to calculate the run time.
regards
Can't Fix Stupid
Thanks, I knew it had to be there somewhere.
Leroy
