585,602 active members*
3,462 visitors online*
    Jun 2006
    31
    PMC load problem
    I have a ISEIKI Fanuc OMate MC , I move it to other location when I boot the CNC display :
    PMC load select
    1. Load from I/O
    3. Run
    4. Run without PMC
    Push 1-5 key
    I do not know why because it still work til I move it.
    I try to key in 4 to select to run without PMC but it still NOT READY
    I cannot select 3 to run
    when I select 1 to load from I/O the screen display:
    PMC loading
    Addess 0000H
    Data 00H
    Push 1-5 key: 1
    Can any one help me to sold the problem
    tungtung
    Jan 2008
    136
    I think you loosened the PMC card when you moved the machine, turn off the machine power and then check all the boards are seated to the motherboard.
    also, check all connectors are in place and not hanging out, use the clamp screws on connectors and boards.
    try control power on again.
    Jun 2006
    31
    Many thank philsereng
    My Fanuc OMate MC do not have the PMC card ,only 2 ROMs OE1 &OE2
    I have tried clear the memory by push Reset+Delete while power up and reloading the parameter
    but the CNC is the same as before .I think I need PMC backup to reloading the PMC as the guide on screen but I do not have one.Does any one help me?
    Can the fanucservicetech explain me about that trouble?
    Tungtung
  1. Help With Dc Load Meter Led
    By dannystooblue in forum CNC Machine Related Electronics
    Last Post: 02-09-2017, 06:03 PM
  2. Z load on vf-3
    By mls in forum Haas Mills
    Last Post: 05-16-2008, 04:54 AM
  3. Need To Load R-14 Onto Xp Laptop
    By Cycle Start in forum Autodesk
    Last Post: 07-19-2007, 04:26 PM
  4. Fanuc 0M PMC load
    By ETNOM in forum Fanuc
    Last Post: 05-27-2006, 08:21 PM
  5. Determining VA load
    By Swede in forum CNC Machine Related Electronics
    Last Post: 04-10-2004, 10:00 PM
