585,982 active members*
4,533 visitors online*
Results 1 to 17 of 17
    Jul 2004
    148
    Question About Edge Finder
    When using an edge finder to touch-off the top of a work piece how does it react? I've never used one yet, but do understand the x and y of how it works on a mill. Does it react with an eccentric movement or similar? Thanks Matt
    Apr 2003
    1876
    They're not for touching off the top. If you do, it will damage it and/or the workpiece. Use an indicator or electronic edge-finder for the top.
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Apr 2003
    1876
    Quote Originally Posted by FLUTE HEAD
    ...Thanks Matt
    BTW, how'd you know I was going to be the one to respond?
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    Jul 2004
    148
    Thats my name too. I should have put a comma.
    Jul 2004
    148
    I'll look into the electronic edge finder. Is it used for x and y also? Where can I find an inexpensive one? Any other suggestions?
    24221
    Are you talking manual mill or CNC 3 axis probe? The majority of 3 axis CNC measuring probes use a precise 3 axis probe (x,y,z) that breaks an internal optical beam (opto-isolator). and they are connected to a CNC dedicated input called skip input which in turn is programmed by a G31. Essentially what happens is an axis move is programmed with a G31 and when the probe trips, that move/line of code is immediately terminated and the position is captured, the code drops through to the next line.
    The measuring routine is in the form of a macro unique to whatever you want to achieve by measuring. The probe has hysterisis that has to be calculated i.e. from the point of mechanical contact to the electronic trip has a certain definite offset which is subtracted from the measured point.
    is this what you wanted, or are you sorry you asked
    Al
    Albert E.
    Sep 2003
    363
    This is the easiest way to find the top of your stock with the cutter installed, spindle OFF. Bring the cutter down close to the stock, lay a dowel pin on the stock next to the cutter, and now raise the cutter until the dowel just rolls under the cutter. Now you know the exact height of the cutter. If it is an odd shaped part and you can’t use a dowel, try this very carefully. Take a short slice of paper of known thickness. Turn the spindle on, lightly hold the paper between the part and cutter, and slowly lower the cutter until the paper is pulled from you fingers. These have worked for me for over 30 years.
    Gary
    Jan 2004
    353
    Quote Originally Posted by duluthboat
    Gary
    Very interesting Gary!
    Never seen this method so I'll give it a go next time I run the Mill!
    (I currently use an electronic but it's 50 mm high so on some projects it can be hard to use)
    Jul 2004
    148
    No, not sorry. I appreciate all the input. Even the simplest subjects we can all learn from. Thats funny, the paper trick has run through my mind. Any more input? Hey maybe a trip laser kit placed above the workpiece at a known distance, when the cutter trips the laser you know you are that distance away. Just talkin outa my head
    Apr 2003
    1876
    Warning about the paper; Don't EVER put your hands or hold anything in your hands next to a moving spindle. If it grabs, your hand could be toast very quickly and very easily. Instead, turn the spindle off and hold the paper, (small piece, 1" square) down flat with a finger and move it back and forth under the tool as you bring it down. You'll feel the paper get tighter under the tool, then it will stop moving. If you want to get close, use the celophane(sp) from a pack of smokes, it's generally about .0003 to .0007" on a pack of Marlboro's
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    779
    Yes, an electronic edge finder will work for all three axis. However it will only work on metal material. If you are ever going to cut plastic then you will not be able to find the edge using the electronic type.
    Jeff Davis (HomeCNC)
    http://www.homecnc.info
    Jan 2004
    353
    Quote Originally Posted by HomeCNC
    In this case I use the Edge finder on the X/Y corner of the vice then do my setup from there .
    Keep it coming guys lots of interesting things coming from this thread!
    Apr 2004
    10
    on the cnc, I use a regular edge finder for the x&y, and a 1" gage block for the Z. On the manual, I just move the table up untill the bottom of the endmill touches the part. For more accurate work, then I walk over to the cnc and grab the gage block.
    Aug 2004
    16
    I've used the paper trick, but instead of holding it put a drop of oil on it and stick it to the workpiece. When the cutter grabs it you are within .001.
    Rob
    Oct 2003
    192
    Well,... everyone has it's own little tricks!
    Me, for X, Y, I have ground a dowel pin to .200 and holding in collet, apr. 200 rpm. I make it black with a marker, move to the edge, last few thousands by .001 increment's, until the black gets wiped off, move tool up above work piece, then one more move .100 increment to center.
    For Z, I use .002 shim stock under the tool.
    Konrad
    507
    I have seen the process in action as Gary described, it really, really works! Just be carefull not to get the fingers caught by the cutter!
    Klox
    *** KloX ***
    I'm lazy, I'm only "sparking" when the EDM is running....
    Sep 2008
    look for it on alibaba.com
  1. Extremely basic machining question.
    By touser in forum MetalWork Discussion
    Last Post: 06-19-2005, 06:51 AM
  2. Edge finders and techniques.
    By redbaron in forum DIY CNC Router Table Machines
    Last Post: 01-04-2005, 08:22 PM
  3. Which came first, Solid Edge or Solid Works?
    By Arnie in forum Uncategorised CAM Discussion
    Last Post: 09-15-2004, 12:25 PM
  4. Hobbycnc controler question
    By chas in forum Hobbycnc (Products)
    Last Post: 09-09-2004, 11:00 PM
  5. HF lathe question
    By rs1300 in forum Uncategorised MetalWorking Machines
    Last Post: 01-19-2004, 06:22 PM
