Mazak VTC-16B
Mazatrol M32B
Program type: G-Code
I was wondering why the spindle doesn't start when using Restart?
The Restart Method I'm talking about is the same one you would use for a mazatrol program.
1) Restart softkey
2) Enter program number
3) Enter Sequence number (N number/Line number in G-Code)
4) Enter Block number (Actual line you want to restart in between N numbers)
5) Repeat 0
6) EIA/ISO Search softkey
7) Cycle Start
I have N numbers on just my toolchange lines. Ex: N1 T1
This is the sequence number I enter in process above. M3 S1000 is on a line
after N1 T1.
Everything works correctly when it comes to restarting the program where
you want it to restart, but for some reason M3 S1000 isn't picked up and the
spindle doesn't start. I've found a work around for now by starting the
spindle in MDI - M3 S1000, and then toggle MEM to restart program.
Maybe this is how a Mazak restart is done. I know Fanucs I used to run would
pick up M3 S1000 and turn the spindle on when doing a restart.
Is this the behaviour of a Mazak restart, or maybe I'm missing something?
