585,761 active members*
4,009 visitors online*
IndustryArena Forum > Community Club House > Bridgeport CNC Retrofit Questions
Results 1 to 3 of 3
    May 2008
    3
    Hi, All found this site from a machsupport forum. I have been using cnc for about 13yrs now. I am familar with hurcos, brigdeports, and hardige's. I have a bridgeport series2 with a boss5 control on it and one of the boards went out of it so I am looking to retrofit it with newer stuff. I am looking for any suggestions on what parts to use.
    Thanks.
    Nov 2005
    256
    You might want to try posting here: http://www.cnczone.com/forums/forumdisplay.php?f=157
    Dec 2005
    3319
    Check out the FAQ section as there are a LOT of questions that have been asked and answered too many timest to count. Especially are those involving steppers versus servo's.
    If you have servo's on your machine, AJAX CNC is essenitally your main optoin, espeicallly if you want to plug and play - sort of...
    If you ahve steppers on your machine, MACH is probably the better option as it is well supported via the members.
    Again, check the FAQ section
  1. Bridgeport Series II un-retrofit.
    By Buddy0228 in forum Bridgeport / Hardinge Mills
    Last Post: 05-01-2008, 08:39 PM
  2. Bridgeport Retrofit
    By ltyunim in forum Bridgeport / Hardinge Mills
    Last Post: 12-12-2007, 02:11 PM
  3. Bridgeport Series II Retrofit
    By Cold Fusion in forum Vertical Mill, Lathe Project Log
    Last Post: 07-01-2007, 02:37 AM
  4. retrofit bridgeport cnc
    By supahonkey in forum Bridgeport / Hardinge Mills
    Last Post: 07-03-2005, 05:54 PM
  5. Bridgeport Retrofit
    By routerman in forum Bridgeport / Hardinge Mills
    Last Post: 03-16-2005, 07:32 PM
