585,992 active members*
5,661 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > fanuc 0m servo not ready 401 alarm
    Oct 2005
    Unhappy fanuc 0m servo not ready 401 alarm
    i have a a2ob-1000-0560 servo drive ..im getting a hcal and tgls light on the drive . i replaced a bad contactor in the main supply to the servo drives easy find i get about 5-10 min till it alarms out .. voltage on ch15-ch16-ch17
    on all 3 drives is 2 volts low but on alarms out on Y-axis ...we picked this dinosaur up at an auction for a extra piece of equipment to handle the overflows ive checked all the connections they seem to be tight ...
    Oct 2007
    179
    Hi Keith,
    My guess is that you have a loose power connection to the servo or contamination in the servo caused by cutting oil or slideway oil TGLS means you are loosing connection to the armature it can also mean the velocity feedback signal is lost .ie if you have a tacho then there could be oil on it causing a bad connection between it and the tach brushes.
    The HCAL alarm baiscally means an overload/exessive current to the transistor module caused by a short circuit in the servo motor somewhere.
    Again this could be contamination inside the servo caused by condensation maybe.. or it could be a loose wire somewhere..
    Hope this helps i would be interested to know what you find!!
    John.
    Try swapping the axis top board with the X axis drive. Make sure you set the jumpers.
    See if the fault stays with the board
    Oct 2005
    forgot about this post put problem was solved by swapping drive boards and problem followed so we purchased board on ebay problem solved
  1. Replies: 2
    Last Post: 09-10-2018, 09:21 PM
  2. Fanuc 401 servo alarm
    By sbp in forum Fanuc
    Last Post: 01-11-2014, 10:39 PM
  3. fanuc servo alarm
    By vpmachine in forum Fanuc
    Last Post: 11-07-2007, 09:33 PM
  4. Fanuc 6m 416 X Servo Alarm
    By Yabbos in forum Fanuc
    Last Post: 08-20-2007, 10:30 AM
  5. Fanuc Servo Alarm
    By herbmarkovit in forum Fanuc
    Last Post: 11-20-2005, 05:53 PM
