586,009 active members*
4,739 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > gibbscam haas post processor
    May 2008
    7
    does anyoone have a post processor file for gibbs to haas????
    May 2007
    If you have legit copy of Gibbs you should have it already. When you go to post your file there's a button on the right side that opens the folder with all the posts you can choose from. I don't have copy with me so I am unable to give you the exact menus but, I assure you it's there.
    Aug 2007
    96
    I have one, but all I had to do was get it from my VAR. You should ask yours. I know if your on maintenance they will probably get it for you with no charge, but will not back it up unless you pay Gibbs for a post.
    May 2008
    7
    THANKS
    Thanks im not normaly the programer i was just using the normal guys computor he called and told me were to find them in the process button on gibbs thanks anyways guys
  1. GibbsCam Post Processor Needed
    By CCAJohn in forum GibbsCAM
    Last Post: 04-11-2024, 07:17 PM
  2. GibbsCam Post Processor Needed Help!
    By MetalZilla in forum Haas Mills
    Last Post: 06-03-2007, 04:11 PM
  3. wire edm post processor for gibbscam
    By pgman68 in forum CNC Wire Foam Cutter Machines
    Last Post: 04-12-2007, 12:59 AM
