586,005 active members*
5,249 visitors online*
IndustryArena Forum > CAD Software > Uncategorised CAD Discussion > cadkey,99,98,97 lost serial codes
    Apr 2008
    78
    i have several cadkey versions but i noly had the code# for 97.
    lost it......
    is there anyway to get new serial codes ro retrieve the old ones?
    any help would be appriciated...thanx
    chuck
    Apr 2003
    637
    What do you mean by serial numbers and what are they used for? If you’re looking for license files to activate your program you need to contact your VAR.
    May 2006
    803
    I have one for 97
    I purchased a Cadkey 97. Private message me it may work, Why not just use Cadkey 98 or better yet 19? I use 19 to make the bucks reliably.
    Been doing this too long
    Sep 2004
    148
    Quote Originally Posted by chaz6966 View Post
    lost it......
    chuck
    You don't need the serial codes. Just load CK99, When the window comes up for you to enter the serial no, and key code, click cancel, and then it should load up just fine.
    May 2021
    Re: cadkey,99,98,97 lost serial codes
    I open up my CadKey98 software and it requests serial code and code key. I have hundreds of 3D drawings on the C: drive and just need to get at them.
    How do I load the CK99 short cut?
    John
  1. Looking for Cadkey 19+ or better yet...KeyCreator
    By jorgemonteon in forum Uncategorised CAD Discussion
    Last Post: 12-16-2010, 07:48 AM
  2. M-codes and G-codes 4 Matsuura ES-1000V
    By maximusek in forum G-Code Programing
    Last Post: 11-27-2007, 01:41 PM
  3. Cadkey
    By mmachining in forum Uncategorised CAM Discussion
    Last Post: 05-01-2006, 10:11 PM
  4. Needed G-Codes For Lost Technology
    By CAMCRASH in forum G-Code Programing
    Last Post: 03-12-2006, 04:59 AM
  5. cadkey
    By drill in forum Uncategorised CAM Discussion
    Last Post: 01-28-2006, 07:39 PM
