585,764 active members*
4,183 visitors online*
IndustryArena Forum > MetalWorking > Casting Metals > Aluminium die casting
    Jun 2008
    Question Aluminium die casting
    Hi Guys,
    I have started pressure die casting of aluminium just recenly. I am doing it with LK machine 500 ton and casting crank cases of 70cc engines. My products weigh around 2500 grams inclusive of runner maximum and machine is good for even 5kgs shot according to specification. My problem is that sticking of material is too high. On average my product sticks inside mould after every 100 shots. Secondly I am getting porsity or even leakage in my product. Being a part of engine leakage is not acceptable.
    How can I overcome these problems?
    May 2008
    15
    improper cooling
    dear doc4ehsan
    The problem of castings sticking to die is not uncommon. This mainly occurs due to insufficient cooling of the dies. from your message it is unclear whether you are using any cooling circuits to your die. Die coatings avoids this probleam to a certain extent but not compleate. it is better to use a cooling circuit in your die to carry the heat away if your mold is large enough.
    Or you will have to provide sufficient time for your mold to cool down between fixed intervals.
    You should ask your die maker if he could make some kind of cooling arrangements for your die. Pls let me know if the probleam is solved.
    Good Luck
    Nav
  1. Aluminium manual die casting technique....
    By axis_control in forum Casting Metals
    Last Post: 11-05-2015, 01:58 AM
  2. Aluminium Die Casting Mould
    By ahmedrehan in forum Moldmaking
    Last Post: 02-02-2009, 02:51 PM
  3. Help: Casting Aluminium
    By djh82uk in forum Casting Metals
    Last Post: 12-11-2007, 05:45 AM
  4. STL and casting
    By Jcadwell in forum MetalWork Discussion
    Last Post: 05-15-2006, 10:01 PM
