I was having trouble with chatter on my mill. I could only take about .100" deep cut using a 3/8 carbide endmill without it chattering. I put an indidcator on my spindle and I don't seem to have any movement in the spindle and bearings seem good. I did take the cover off the head and there are rollers inside that roll on a rail as the z axis moves up and down. These rollers did not turn because they are all too far from the rails. There are 4 plastic plugs on each side of the head that can removed to allow adjusting of these rollers. The spindles of the rollers are eccentric so turning them adjusts them closer or farther away from the rails. I snugged mine all up until the roller just touches the rails and the machine cuts alot better now. I can take a 1/2" deep cut in mild steel now using a 1/2" endmill. My question is how close to the rails should these rollers be? I just hope that the way I have them adjusted now is not placing some kind of bind on the spindle. I can still turn the ball screw very easily when the servos are off.
