G'Day Friends
For those that are interested at moment I am actually replacing my 1hp VFD driven spindle with a 2Kw (3hp) servo motor. This drives the spindle with a toothed belt directly from motor with a slight ratio of 1/0.8.
Rpm range from 0 to 2000 no changing belts or gears. The other advantage I can swap axis and use the spindle as a Rotary "DEG" as "C".
The toothed pulley to the spindle is only plastic keyway held in case of an "oopsy" moment as the point to give first. Just working on the mounting bracket now and once mounted I will be upgrading the control side to Ethernet driven Smooth stepper, then to Mach4.
