Originally Posted by
Matt@RFR
......My original plan was to use gauge pins that measure at the low side and the high side of the tolerance (+/-.002", incidently, on a R.477") and simply lay them in the part and use a loupe to see where they make contact with the part. I think that would've worked fine, but the gauge pins are taking WAY too long to get here and I need to get these parts out soon.....
Do you need gauge pins made to some specific tolerance? Is it not possible to make your own?
