585,877 active members*
3,114 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Anti Whip solution for long screws?
Results 1 to 16 of 16
Threaded View
    Jun 2007
    84
    I posted this on another thread in the Open Source forum... but I don't think it is getting much visibility there. I am really curious about peoples thoughts on this. Do you think it would work?.....
    I'm going to be using a 1/2inch acme which will be 55 inches long. I'm worried about whipping as well. I devised an idea to stop the whipping, not sure if someone has used it before.
    Basically... the screw will have several spring loaded doors on each side.
    The hinges will be double action such as this... they bring the door to the "closed" position, but let it swing both directions.
    http://www.hardwaresource.com/Store_...ts.asp?Cat=118
    Planning to use a 1/2ID teflon washer of some sort in between and cut in half.
    Not sure if it will work, and is just a contingency plan, so I may never know.
  1. Anti Backlash nuts to fit RF-45 screws
    By Climatepro in forum Benchtop Machines
    Last Post: 04-30-2019, 03:47 PM
  2. Anti-sieze for insert screws
    By dinnese in forum CNC Swiss Screw Machines
    Last Post: 02-03-2012, 05:11 AM
  3. anti backlash solution
    By elteks in forum DIY CNC Router Table Machines
    Last Post: 03-11-2010, 02:53 PM
  4. anti whip block needed with dumpstercnc nuts?
    By forgetcolor in forum Commercial CNC Wood Routers
    Last Post: 05-16-2009, 05:33 AM
  5. How to support long lead screws....a solution
    By spunky1974 in forum Linear and Rotary Motion
    Last Post: 11-07-2006, 06:11 PM
