Michael, your zero thickness issue is coming from the inside edge of the cut. I always try to never cut right along the surface. Instead, if you were to simply cut from one profile to the next, you should not get a error, if you do it's because one edge of the profile is directly on the surface. Instead, if you were to add to those profiles and extend them through the surface, into the center cavity just a little bit you'll lose the error in short order. Also your guide curves shouldn't have to follow the surface on the inside, instead they should be able to go directly across from one profile to the other. On the outside, you'll want them to follow your profile, but on the inside it will be just cutting through air, so it won't matter..
Hope that's all clear..
J
JerryFlyGuy
The more I know... the more I realize I don't
