I was wondering if anyone could tell me how to set the date and time on a Mazatrol T32-2 controller. It's kinda bothering me that it's off. Thanks
It'd been so long, if I remember correct it under Diagnosis/Version pager.
The best way to learn is trial error.
...Was hoping someone with that controller would chime in first...
I've got a 640-T, so don't know for certain on yours, but on mine it's simple. Since mine runs on Windows 95, just run the cursor from the mouse pad up to the Windows toolbar (on top or bottom, wherever yours resides) and run it over the buttons to get the fly-out. From there you can go into the Windows screens and change all of the Windows defaults and settings.
Isn't that where you hit the Version page, then one of the menu data buttons and input 1131 and "adjust" pops up? Then you input the time and date?
Lee
Sorry I don't remember which menu data button under the screen it is. I just keep trying them all until I hit it.
A. Put the machine in HOME MODE
B. Push the [E-STOP] button
C. Push and Hold the [RESET] button
D. While holding [RESET]. Hit the [DOWN] arrow key. (cursor will show up in clock section)
E. Input the date
F. Hit [INPUT]. (The cursor will move to the time display)
G. Input the time
H. Hit [INPUT]
I. Release [E-STOP]
Matt- The procedure posted is correct, you just have to make sure the date and time are in the proper format. YY.MM.DD and HH.MM.SS (24 hour)
I have a copy of the instructions I got from Mazak for T32 clock setting. If you want I'll email you a PDF copy to keep with the machine.
