585,692 active members*
5,098 visitors online*
IndustryArena Forum > MetalWorking Machines > Hyundai Kia > Hyundai Hit8s with siemens 840c
    Jun 2008
    Hi there.
    Im having big issues with my lathe. Z axis started to judder and alarm out (ORD1 contour monitoring Z). It does this randomly. Now the X is jumping and alarming out when trying to reference (ORD1 contour monitoring X). Our main service company have looked at it numerous times and now washed their hands of it! Anyone got any ideas, ive checked all connections. Any help will be much appreciated.
    Many thanks,
    Marx
    Aug 2008
    I had this same problem and the tachometer in the servo was bad.
    Mar 2006
    194
    Hallo Alger Hallo Marx..
    a have this maschine..
    Sorry m english is not so good..
    a translate you in google traslater..
    ORD ist OrdnungsNumber..
    Bat coming this is not a problemm.. (small-Problemm)
    Make a new DriftAbgleich..
    A say you and you can make it..
    you mst make 611. Driver for Achsen..
    klemme 63,65 und 663 give her 24 Volt..
    the driver has a led.. Yellow must run..! ReglerFreigabe.
    go and make 56 und 64 Sollwert Null a brigde..
    an poti must drehen.. left or right.. you understand.? a hope.!
    __________________________________________________ ____
    okey make all the kabel in originel
    your Achse must zero of zero sein.. in the Monitor.
    Make..
    Softkeys/
    Diagnose/
    Service-Anzeige/
    NC-Service/DriftAbgleich..
    Please press this key 3 mall.. 4 mall..
    you look..
    Deine maschin has good and work..
    then If you have questions
    My Problemm for this maschin Z has not Tork.??
    a have checked Driver.. (All)
    a make monday morning check the Motor for achse..
    Gruss Demir.
  1. Hyundai Hit8s w/siemens840c
    By Johnny9 in forum Hyundai Kia
    Last Post: 07-26-2016, 02:48 PM
  2. Help with power for Siemens 840C
    By dfstrasser in forum CNC Machine Related Electronics
    Last Post: 05-19-2010, 11:29 PM
  3. help with parametric programming on 840c
    By craigh10 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-10-2009, 08:35 AM
  4. Hyundai SPT-V30
    By kevinkoons in forum Uncategorised MetalWorking Machines
    Last Post: 03-03-2008, 04:09 PM
