585,662 active members*
3,325 visitors online*
    Mar 2008
    18
    Used JET BD-920N Lathe
    Yesterday, I went with a friend to a bank auction to help him load his purchases. Among the house and garage items up for bid was JET BD-920N lathe. I could not see it run, but according to the manual, everything was there( including the base cabinet). No rust or obvious damage. I found the purchase receipt in the manual(2006). Also included were a HF 39083 QCTP9 (still in the box), an 8 piece brazed carbide tool set, numerous carbide inserts and holders and some HSS tool blanks. I got it for $400.
    This mornings inspection revealed a trashed 80T plastic gear, but there is a spare in the gear change set.
    Should I order more 80T plastic gears or get a metal 80T from Grizzly?
    I plan on going through a complete start up prep and alignment, so I will have more Newbie questions.
    Any advise will be welcomed.
    Mike
    Mike Broach
    Nov 2004
    260
    Smile
    That is a pretty sweet deal you got.
    Don't worry about the gear you may never need it.
    I would not replace it with steel two reasons, it is the weak link on purpose in case there is a overload this will protect all the other gears, allso it reduces the noise when the gears are running.
    Good Luck with your Lathe.
  1. Jet BD-920N Opinions/Recommendations
    By kwcurtin in forum Uncategorised MetalWorking Machines
    Last Post: 06-11-2021, 04:15 AM
  2. Converting my Engine Lathe to an 8-Station Turret Lathe!
    By widgitmaster in forum Uncategorised MetalWorking Machines
    Last Post: 08-09-2018, 04:56 PM
  3. cinturn lathe with an acramatic lathe
    By PETE1968 in forum Mastercam
    Last Post: 10-16-2008, 02:37 AM
  4. What's the different between a CNC Swiss Lathe and a regular CNC lathe?
    By squale in forum Uncategorised MetalWorking Machines
    Last Post: 11-09-2007, 04:54 PM
  5. Anyone have a mini cnc lathe or medium sized cnc lathe
    By nymachinist in forum Mini Lathe
    Last Post: 01-24-2006, 03:36 AM
