hey!
yeah im sure you all get really tired of this question... but a couple quick-ish searches didn't answer my questions here.
want 4 axis, im thinking the xylotex looks really nice. want to make own mounts and completely lost on ballscews...
i have an x3 mill, and around x-mas id like to cnc it. my budget is around 1000 not including software, obviously under is nice. here is a page i just made myself:
http://www.xylotex.com/4AxSysKit.htm- 380$
4 axis driver, 4 269oz nema 23’s, PSU, fan, cable. Can it use a larger
Stepper on the Z axis? Will 269oz be good enough for rotary table, x and
Y axis? For x3 mill what should be used for Z axis?
http://www.cnc4pc.com/Store/osc/prod...products_id=47 57$
Breakout board- thoughts? Better alternatives?
http://www.harborfreight.com/cpi/cta...emnumber=44859 525$
for grinding ballscrews- is it up to the job?
http://www.machsupport.com/purchase.php 160$
mach 3- any advice?
http://www.solidworks.com/ 140$/Free
solidworks- what versions?
Cam software- what do you recommend for 4 axis?
Ballscrews- what do you recommend? Id like to grind and turn them myself as an excuse to buy a lathe.
Motor mounts- id like to do this myself. What plans are popular? How is the Z axis mostly done?
What other nuts, bearings, et cetera are needed? Im pretty lost here.
Any good guides for learning g-code? Is cam necessary? Does writing your own g-code take the place of using CAM software? (forgive the noob questions...)
Cnc question- how does your mill know where to start cutting on the Z axis? I mean how does it know where your work piece is, im lost on how to start milling, or where to set it so you start the toolpeice where its supposed to?
ANY advice or tips relevant or not relevant to the thread are welcomed...
regards
