586,009 active members*
4,744 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Open Source Controller Boards > How to connect ELM Board and OSMC Board ?
Results 1 to 3 of 3
    Jun 2007
    6
    I have a osmc board.
    I have a ELM-chan board.
    How I can connect the 2 signals pwm on OSMC board ?
    Because the HIP4081 is not managed like a IR2184 for example!
    Thank you for advance
    PS : I'm a french guy and i write very bad english ;-)
    May 2006
    2420
    Basically the 2184 turns on the low side fets if no input signal is recieved, in the case of the HIP4081 you have to give the low side an input to turn it on, with the two PWM signal's from the Elm Chan board, take one and connect it to both "B High in" and "A low in", the other PWM signal goes to both "A High in" and "B Low in".
    This should work.
    Cheers.
    Russell.
    P.S. I think your English is a lot better than my French
    Jun 2007
    6
    I would test that this week !
    Thank you
    Stephane
  1. Breakout board, Relays on board?
    By Cooper in forum Open Source Controller Boards
    Last Post: 06-10-2007, 01:55 AM
  2. Replies: 7
    Last Post: 02-10-2007, 04:45 AM
  3. 80V board
    By sdantonio in forum Open Source Controller Boards
    Last Post: 06-02-2006, 08:18 AM
  4. 24v ps for IO board
    By miljnor in forum Servo Drives
    Last Post: 02-23-2006, 03:24 PM
  5. Bad Board?
    By fool in forum Xylotex
    Last Post: 02-06-2006, 08:30 PM
