585,743 active members*
4,950 visitors online*
    Jun 2008
    614
    Fanuc controller?
    just wondering is there a price effecient Fanuc controller for an X3 CNC setup? im sure if there is one its the more expensive stuff...the only reason i ask is because Fanuc is all we use at work and its what im farmiliar with...
    24220
    AFAIK the 0 is still the cheapest, I have not used the 0i series, however.
    Mitsubishi is very close in operation and it would not take you much to cross over to a similar make as this.
    But generally Fanuc is not cheap to the Retro-Fitter.
    Al.
    Albert E.
    Nov 2004
    260
    Unhappy
    Quote Originally Posted by mwood3 View Post
    There is a inexpensive Controller Software "ZeusCNC" that is based on Fanuc.
    The interface is a bit different but easy to pick up if you have Fanuc experience.
    If you are talking about the complete Hardware and Software from Fanuc yes I think that would be expensive and most of all probably not compatible with your "Step and Direction" Drivers.
    Other than that I would love to have one of those Controllers too.
    Good Luck
  1. Fanuc 18i-M controller
    By Wjman in forum DNC Problems and Solutions
    Last Post: 10-01-2010, 06:02 PM
  2. Fanuc controller
    By royt in forum Want To Buy...Need help!
    Last Post: 06-02-2008, 04:47 PM
  3. Fanuc 10T F Controller
    By adaptaflex in forum Fanuc
    Last Post: 01-28-2008, 07:51 PM
  4. fanuc 10t controller
    By merv385 in forum Fanuc
    Last Post: 02-18-2006, 05:52 PM
  5. GMF Fanuc L-100 Robot R-F controller
    By whiteriver in forum Fanuc
    Last Post: 01-28-2005, 05:16 PM
