584,808 active members*
5,158 visitors online*
Page 1 of 2 12
Results 1 to 20 of 23
    Apr 2007
    641
    Biesse , Rover 321R
    Hi All, Anyone has manuals of this machine?
    Its A Biesse Rover 321R . Is a point to point and I want to change to newer program.
    Luis
    Feb 2008
    482
    i have manuals but only in paper format. they are all available to order from biesse.
    by newer program what do you mean?
    the 321 is a very capable machine if programmed correctly.
    Oct 2008
    slm arkadaşlar bana rower321rnin cad3 dönüşüm programı lazım elinde olan varsa lütfen bana verebilirmi çok ihtiyacımvar teşekürler
    Feb 2009
    14
    Hi, luis,
    I have the same problem.
    If you would find a solution please let me know.
    I have a Biesse Roover 322.
    I'd like to run the machine with the V-carve of Aspire. Software from Vectric, but I cannot seem to find a way to communicate with my machine.
    It has a floppy-drive, but it isn't FAT formated.
    I have some serial ports, but don't seem to find how to manipulate them...
    did you already find something ...
    Feb 2008
    482
    click on my name and read my other posts. lots of info there!
    Oct 2010
    Quote Originally Posted by lamicron View Post
    Luis
    Hi all,
    Now we have a Rover 321R(NC481- 1997), but now it alarms "av20 s011 i055 ". So we need to re-format and restore the back up files.
    But now our back up floppy disk failed, so can not restore this machine.
    Anyone has back up disk of this machine(a generic RV321R data disk) ?
    Please help us. Thanks
    Feb 2009
    14
    Quote Originally Posted by dhcuong102 View Post
    Hi all,
    Dear,
    We have a Rover 322 but the same NC481.
    I have the boot disk...
    mario
    Oct 2010
    Quote Originally Posted by Mario B View Post
    Dear,
    mario
    Dear Mario,
    Thanks for your reply, our boot disk remain work.
    Because last time back up battery inside the CNI control is empty. So machine has lost the data. So we need a back up disk(a generic RV321R data disk) to restore it.
    Now it alarms "av20 s011 i055 "
    av20
    Message ......... Error in the machine data
    Help................. Please check machine data in D>
    s011
    Message .......... General error for machine data(error in reading-in or data inconsistent with machine).
    i055
    Message .......... Drive D> not formattedfile formatto not found)
    Feb 2009
    14
    Hello,
    I don't understand what you mean with backup disk.
    Normaly the D:\ drive is the diskettedrive and this is only for programs you wrote,but hase nothing to do with the working of the machine.
    Of course, if the directory is set on the RC481 to look for programs on the D:\ drive and there is nog diskette, it will give you an error.
    you can change the directory from D:\ to C:\ and the error will be gone....
    do you know how to change directorys on the RC481 ?
    you can contact me on my mail
    [email protected]
    yours,
    Mario
    Feb 2008
    482
    the d drive and c drives are both ram drives
    d stores fixed cycles, c stores programs (both will be lost if battery died)
    the floppys will be drives a and b
    i have 321r atc boot disk.
    if battery was flat you require all other backup disks too including language disk. these are machine specific.
    does your machine have tool changer?
    you should be able to get these from biesse by quoting machine serial number
    so much to learn, so much to pass on.
    Nov 2009
    120
    HELLO
    I HAVE A BIESSE ROVER 335
    BUT WE CAN SAVE PROGRAMAS ALSO MACHINE DATA , WE NEED TO LOAD PARAMETERS AND DE DISK A AND DISK B SAY NO DISK, UNFORMAT .
    I NEED TO LOAD BUT WE CAN NOT BECAUSE DISK NO READ. SOMEBODY CAN WE HELP US?
    REGARDS
    Nov 2009
    120
    I AM SORRY. ROVER 335 WITH RT 480
    Jul 2012
    HELP - BIESSE MANUALS FOR ROVER 321R
    Hi Guy's,
    Need some assistance if someone can help?? I've just purchased a Rover 321R however it never came with the manuals. Did anyone happen to find a soft copy of them? The guy at Biesse quoted me $450 to photo copy them for me...... any chance of a soft copy from anyone?
    Cheers
    Biggles275
    Feb 2008
    482
    [QUOTE=Biggles275;1147090]Hi Guy's,
    i have a few manuals in paper only
    i had to order mine direct from biesse through the uk agent.
    the manual is pretty thorough and comes with a full fault code book which is indespensible. (even one space wrong or one item in wrong order will throw an error when machining even if the part draws ok in simulation)
    a full machine manual is approx £150 (uk sterling) but you really must have it.
    machine fault codes appear to be different for different models! i have 321r atc and 335 (now converted to mach3)
    i searched for ages and couldnt find a pdf version anywhere.
    they are way too big to scan or photocopy!
    even with the manuals you have a very steep learning curve ahead to master these machines. biesse do everything differently to everyone else!!!! be prepared to spend 10 minutes to program a square, half hour to program an elipse etc etc
    Nov 2009
    120
    hello my name is eduardo
    i am interesting in converter rover 321 with mach 3
    could you help me
    ihave manual electrical , programming and maintenance , errors
    Nov 2009
    120
    my email is [email protected]
    i have manuals
    regards
    Nov 2009
    120
    hello i have a machine rover 335 some have any drive floppy dirve because my floppy doesnot read.
    regardas
    can you help us
    Feb 2008
    482
    Quote Originally Posted by tecnicocnc View Post
    regardas
    can you help us
    if your battery has gone flat and memory lost you will need to get biesse in to reinstall drivers etc for floppy to read. (mine did that so i converted to mach 3 but its a huge job)
    Nov 2009
    120
    but we have floppy drive fail , do you any ?
    for sell?
    Feb 2008
    482
    did memory back up battery go dead or just floppy drive not work?
    a standard floppy drive can be used but must be configures as CN0 (non standard)
Page 1 of 2 12
  1. Biesse rover 36 postprocessor
    By Ninjabiker in forum CNC Machining Centers
    Last Post: 04-14-2023, 07:05 PM
  2. Biesse rover
    By eng_semsem1980 in forum Biesse
    Last Post: 01-06-2016, 08:18 PM
  3. Biesse Rover 22
    By paul sharpe in forum Education - Teachers and Students Hangout
    Last Post: 09-22-2013, 09:35 PM
  4. Biesse Rover 20 NC410
    By Jamf2 in forum Biesse
    Last Post: 10-12-2010, 11:55 PM
  5. microvellum for a biesse rover 4.4
    By robbie prime in forum CNC Machining Centers
    Last Post: 07-07-2009, 05:19 AM
