585,959 active members*
4,309 visitors online*
IndustryArena Forum > CNC Electronics > UHU Servo Controllers > Old Regular UHU (for 60V to 80V and less)
Page 1 of 5 123
Results 1 to 20 of 91
    1050
    THis thread is dedicated to all the posts which use the original PCB design for the UHU, this is also meant for people who are using PCB from manjeet and others following the old format PCB.
    Nov 2006
    16
    UHU Power Supply.
    I have just finished testing my new power supply for 3 standard UHU's running ametek servos (38v, 12amp max) The power supply uses 2 Laminated core transformers (350va?) in paralall, 2 large caps and 10a fuses between each UHU. It produces 50v no load, and when I draw 8 amps from it it drops to 47v My question is can i use this power supply with my ameteks (38v) or will that cause damage to the servos?
    Thanks for your help on this one.
    Regards.
    1050
    I would not!
    May 2006
    161
    The power supply for your 38V motors should be around 44V (+15%). 50V is not so far above so I think they will run just fine. Surely they will heat a little more but this should be examined during testing.
    As a reference I have my 56V-rated motors running with a 66V PS. Of course if you are not going to use the full speed potential of your motors you could definetely go with a lower voltage PS - say 35-40V.
    Todor
    Nov 2006
    16
    Thanks, thats what i thought. I definately will need the full speed potential of my motors as they are only rated at 900rpm. On my Y axis of my Mill Drill i m converting i am using a 2.5mm pitch ball screw. I will need to direct drive this axis to come even close to fast enough rapids. (37mm/s)
    1050
    Hi Mike,
    do let us know the results!
    RGDs
    Irfan
    Jul 2006
    Hello,
    For almost 2 years I'm trying to start building a new CNC machine.
    When searching the internet I came accross the UHU controller.
    Last year I ordered the Controller and Crytals with Uli Huber.
    And with the last PCB action on the german Message board Peters' CNC ecke
    I ordered 6 PCB's (the old layout 20/10/2005).
    Now I want to order the parts for putting the UHU board's together.
    I found so many threads on the net CNCzone and CNC ecke about the controller, that it's almost impossible for a newbie to filter all that info.
    Now is my question. Does someone have single and clear parts list for ordering all the elctronic parts. I know that one can find such a list on
    http://people.freenet.de/Mode1/UHU_P...uecklisten.xls.
    But for me there's still too much not clear. For instance
    I want to use the opto3 option: HCPL2231(stated by Uli as the best option).
    Then in DIY servo controller thread, tomkroscavage (05-23-2006, 08:04 PM)wrote when using this optocoupler: "If you are using the HCPL-2231 just do not insert R18 and R25 as this opto comes with internal schmitt-trigger and
    push-pull-drivers and is already TTL compatible."
    So is there someone who can give me a non-ambiguous list for building a UHU controller using IRFP260 (150V DC and 30A) and HCPL2231
    Greetings Sam
    Dec 2005
    313
    Quote Originally Posted by simmo993 View Post
    If he is right then it works like this:
    Many opto couplers work just like a hand switch.
    A switch does not give any voltage or current.
    Imagine a hand operated switch between pin 7 and pin 5 of IC11 opto3.
    If the switch is open, then there is no current from +5 volt through R18, through the switch to GND.
    As a result the voltage on pin 7 will be +5 volt.
    If the switch is closed, then there flows a current from +5 volt through R18, through the switch to GND.
    As a result the voltage on pin 7 will be 0 volt.
    The voltage on pin 7 comes from the +5 volt via R18.
    Not from pin 7 itself.
    R18 is in this case called a 'pull up' resistor.
    This is how many opto couplers work.
    With the HCPL2231 opto coupler it works different.
    It does not work like a switch.
    The pin 7 of the HCPL223 works as a small voltage supply.
    If the HCPL2231 gets a ON signal, it will create its own +5 volt signal on pin 7.
    Then there is no need for a R18 pull up resistor to create a +5 volt.
    If the HCPL2231 gets a OFF signal, it will create a 0 volt signal on pin 7.
    With a HCPL2231 you do not need the R18 pull up resistor.
    And R25 is also not needed, it does the same for the other channel of the HCPL2231.
    That is, if he is right.
    I have looked at the HCPL2231 datasheet, with my limited knowledge i can not see if the pin 7 indeed works like a small voltage supply.
    Hopefully someone with more knowledge can tell us :-)
    On the other hand, leaving the R18 and R25 in is no problem with the HCPL2231.
    It probably works fine.
    Can someone "officially" confirm this ?
    http://www.datasheetcatalog.com/data...CPL-2231.shtml
    Vroemm.
    Jun 2008
    9
    Quote Originally Posted by vroemm View Post
    Vroemm.
    Yes, the HCPL2231 does not need a pullup on the output ( stated in bold on the first page of the datasheet under features ). It can directly drive 4 TTL loads.
    It should work with the pullups in the circuit if the resistor value is not to low. The only difference should be slightly slower slopes of the signal.
    Klaus Leiss
    Dec 2005
    313
    Quote Originally Posted by LeissKG View Post
    Thanks for the info.
    I have added it to the UHU wiki.
    http://gsst.wikispaces.com/UHUget
    Vroemm
    Aug 2006
    2758
    Klaus Leiss
    True, but your UHU board will require both pull-up resistors if you are using a 74HC14 chip instead of the 74HCT14 or a plain 7414N (or 74LS14) chip.
    Kreutz.
    Dec 2005
    313
    Quote Originally Posted by kreutz View Post
    Oeps :-)
    The parts list says the IC10 is a 74HC14.
    Best to go from there.
    I have removed the comment, about removing R18 and R25, from the uhu wiki.
    Thanks Kreutz !
    Vroemm.
    Feb 2005
    32
    Hi there
    I want to build this one but where can i find the PCB G-codes for the UHU servo card ?
    Thanks i advance.
    Per
    1050
    are you planning to route out the pcb on a blank board
    Feb 2005
    32
    Yes, on my router.
    1050
    there was a plt file some where you might search the old UHU thread for that in the initial few pages, also there were pdf files.
    look into vroemms wiki, you might find all the files there.
    Feb 2005
    32
    Yes, i have found them but i need them in another format eg G-code or Eagle files so i can handle them in a proper program and run it in Mach3.
    1050
    not that I know of!
    Feb 2008
    553
    Question New UHU assembly
    Hi everybody !
    I got the parts from Reichelt.de and made the PCBs, after verification the PCBs have only a 35µm copper layer on them not the 75µm claimed in the parts list.
    Since it's my first "high" voltage/current project, i was wondering how much amps could a 35µm UHU PCB stand with no problem ?
    I didn't remove the toner transfer yet because i don't know how to protect the copper from corrosion & heard that tin plating a PCB lowers the circuits frequency so, does anyone has a working solution ?
    Is there a way to improve the PCB to make it more reliable ?
    For those using the old PCB, can you please post some pics of your setups ?
    (bottom views apreciated)
    Thanks !
    cnc2
    Jun 2008
    9
    Quote Originally Posted by cnc2 View Post
    Hi everybody !
    Have a look at http://de.wikibooks.org/wiki/Bild:Cu..._(1oz_ext).PNG
    This is not a problem at the frequencies used by UHU.
    cnc2
    If you find that an trace can not carry the required current at 35 µm thickness, you can solder a wire on the affected trace.
    Klaus Leiss
Page 1 of 5 123
  1. Replaced regular threaded rod with ACME leadscrew
    By jeffmorris in forum DIY CNC Router Table Machines
    Last Post: 06-06-2008, 08:36 PM
  2. What's the different between a CNC Swiss Lathe and a regular CNC lathe?
    By squale in forum Uncategorised MetalWorking Machines
    Last Post: 11-09-2007, 04:54 PM
