585,981 active members*
4,530 visitors online*
Thread: ezpath fault
    Jun 2008
    ezpath fault
    hi guys,
    got a problem on bridgeport lathe with ezpath s system.
    interrmitant fault.
    gp fault-fatal error
    m/c integrity is not compromised
    software will try to restart to clear the error
    system error-possible pointer error.
    any ideas
    dave
    Nov 2004
    3028
    This is a mother board fault. Check your +5 VDC logic supply. You may find this low. Clean the mother board edge connection and reseat it into the backplane.
    Also look if the logic power supply cable plugs into the backplane or if it uses the screws and terminals. There was a recall/upgrade to a harness that eliminated the plugs. Too much resistance. If you need to adjust the power supply. It has to come off the Control In a Box front cover as the adjusting Potentiometer is hidden. Be careful. Electricity can bite.
    Also EMI told me that these power supplies were not self regulating even though they had the potential. He was working on a add on voltage regualtion kit.
    George
  1. Bridgeport/Romi EZPATH Schematics
    By NC Cams in forum Bridgeport / Hardinge Mills
    Last Post: 06-25-2011, 12:00 AM
  2. Ezpath Data Inquieytigation
    Last Post: 01-18-2009, 07:12 AM
  3. Ezpath Iiis Error Msg
    By Zombiestomp in forum Uncategorised MetalWorking Machines
    Last Post: 10-27-2007, 03:08 PM
  4. EZPath DX32 control help needed, please!!
    By VSMIGuy in forum Bridgeport / Hardinge Mills
    Last Post: 01-28-2007, 05:49 PM
  5. Bridgeport EZPath help needed!
    By VSMIGuy in forum Uncategorised MetalWorking Machines
    Last Post: 01-09-2007, 12:58 AM
