Originally Posted by
Kiwi
I'm still using V20 to produce code for 2.5 G-Code and generally been satisfied.
My problem with this drawing is the Gcode BCC is producing (just at one point) is not the same as the drawing.
The picture attached shows a line from X28.424 Y-11.3027 to X16.1257 Y0.0 but the code generates the end point as Y0.4 (should be Y0.0)
The controller stops at this point because the next line has G02 (circular interpolation) and the math is incorrect.
Any suggestions why the gcode is wrong?
Kiwi buddy, had the same problem with V19. The fix that I used was to create a point and use the Move to point function on the CAM side to place the cutter where it needed to start.
What BCC does if you previously generated code, delete or undo, then go back to regenerate code, it starts the tool from where it left off of the first generation.
I hope this is the correct interpretation of what your asking.
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
