584,866 active members*
5,153 visitors online*
Results 1 to 6 of 6
    Feb 2006
    1792
    G71 type I and type II cycles
    Earlier, there was only type I cycle (I think so). Type II cycle was introduced to take care of undercuts or pockets along the length of the job. The control identifies these two cycles on the basis of whether only X is programmed in the P block, or both X and Z are programmed. Earlier, Z was not allowed in the P block (in type I cycle). My question is that, if we program both X and Z in the P block, for a job which has monotonic increase in both X and Z (i.e., has no undercuts, hence suitable for type I cycle), what will happen?
    Jul 2005
    12177
    I don't know about any other machine but on a Haas nothing unusual happens if you have X and Z in the P block; the cycle runs fine whether it is monotonic or non-monotonic.
    Feb 2006
    992
    nothing should working fine.
    The best way to learn is trial error.
    Feb 2006
    1792
    radius compensation in Type II G71 turning
    Fanuc 0i manual says in G71 type II section:
    "The offset of the tool tip radius is not added to finishing allowances. In turning, the offset of the tool tip radius is assumed to be zero."
    Does it mean that radius compensation (G41/42) is not possible in type II turning?
    Jul 2005
    12177
    On some machines tip compensation is not active during the G71 but is applied in the G70 cycle. It is necessary to make the finish allowance large enough to include the compensation amount. As far as I know this applies to both type I and II.
    Sep 2008
    48
    examples
    G71 TYPE 2
    O1234
    G97M3S1500
    T0202
    G0 X71 Z1
    G71 U3 R1
    G71 P1 Q2 U1 W0,5 F0,25
    N1 G0 X50 W0,1
    G1 Z0.
    X60 Z-5
    Z-20
    X57 Z-23 **********
    Z-30 *********
    N2 G1 X70
    G0 X150 Z200
    M30
    (ATTENTION TOOL ANGLE)
  1. What type of CNC router?
    By edlee in forum Want To Buy...Need help!
    Last Post: 03-06-2008, 06:48 PM
  2. What type of oil to use
    By Grego in forum Shopmaster/Shoptask
    Last Post: 12-22-2007, 08:55 PM
  3. CRC Type
    By binzer in forum GibbsCAM
    Last Post: 07-06-2007, 05:48 PM
  4. what type of control
    By skippy in forum LinuxCNC (formerly EMC2)
    Last Post: 10-12-2005, 11:36 AM
  5. what type of CNC do I need?
    By Goldhunter_2 in forum Mechanical Calculations/Engineering Design
    Last Post: 06-25-2005, 04:57 AM
