585,974 active members*
4,359 visitors online*
IndustryArena Forum > Hobby Projects > I.C. Engines > What is this called a "internal side crank engine" ?
    Nov 2007
    5
    I was trying to come up with an idea how to improve bearings in a fractional HP low RPM engine by using ball bearings what do you think ? I think the side crank design is the only possibile way to easily replace it's bearing when the bearing is a ball bearing. The two arrows indicate where the two halves of the case bolt together.
    Attached Thumbnails Attached Thumbnails open crank engine3.JPG   open crank engine3.bmp
    Oct 2006
    708
    See page 20 of http://manuals.hobbico.com/osm/fl-70-manual.pdf for another way to achieve the same thing.
    Nov 2007
    5
    If this as yet untested design caught on I guess it would be the first time an IC side-crank engine went from being made for reasons of ease of manufacture as in the case of model airplane engines to reliability and serviceability. If you like the idea of a side crank then the only main difference between the two designs (my drawing and the OS FL-70) is my incorporation of a internal flywheel ,the reason I did that is for reasons more of what I don't know than what I do know although I know it reduces stress on the main bearings, reduces vibration and is probably more compact. Also this engine is intended for stationary use applications or where weight isn't a factor and to run at 2,000 - 4,000 RPM.
  1. Making Large "Turner's Cubes" on an Engine Lathe
    By widgitmaster in forum MetalWork Discussion
    Last Post: 08-13-2019, 08:40 PM
  2. "Fixing" bent engine valve?
    By mmmjboner in forum Bending, Forging, Extrusion...
    Last Post: 07-16-2007, 09:40 PM
  3. V18 "Internal Error"
    By mikesos1 in forum BobCad-Cam
    Last Post: 02-06-2005, 06:28 PM
