585,987 active members*
4,467 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > got bored today Quick change knurl
Results 1 to 9 of 9
    Sep 2004
    144
    made a knurl tool for my quick change on my sherline. took about half hour on my shoptask. stole some parts from the shoptask lathe but i made the body. here a link to the pictures http://www.rainman229.com/knurl.shtml
    6855
    Nice job
    Aug 2004
    48
    Exclamation
    Hi there, I read this concerning Bump Knurls like the one you posted.
    From Mini-Lathe.com
    Bump type tools are not recommended, especially for small lathes, because they impose considerable tangential force on the spindle which could lead to excessive spindle bearing wear. The shaft of the bump-style tool can be clamped directly in the mini-lathe toolpost. The head of the tool can rotate up or down on the pin that attaches it to the shaft so that the wheels automatically center themselves on the workpiece. Again, though, I do not recommend this style of tool for use on the mini-lathe due to the high forces it imposes on the spindle bearings In the scissors-style tool the forces are imposed on the clamp arms rather than on the lathe spindle.
    Thats why I made my El Cheapo clamp knurler and got rid of my bump one.
    .:: gdl357 ::.
    Sep 2004
    144
    i look at this way i don't use it or need it enough to be concerned. most of the stuff i work with is soft. personaly if i was going to knurl steel or stainless i wouldn't use it.
    oh thats my next project cheappo style for quick change.
    Sep 2004
    144
    Got bored again made a clamp quick change today.
    Attached Thumbnails Attached Thumbnails CLAMPKNURL.jpg   CLAMPKNURL1.jpg   CLAMPKNURL2.jpg
    Apr 2003
    302
    Now that one I'd like to buy (cheap).
    Sep 2004
    144
    i might be willing to sell that one. make an offer
    Jul 2005
    442
    Do you have the dimensions on the dovetail?
    I am creating my own QCTP but would like to make it fit standard tool holders.
    Aaron
    May 2005
    2502
    Quickchange Dimensions
    Aaron, buy one AXA-sized quick change toolholder from Lathemaster for $16.95. He has the cheapest ones I have found. Now measure that one for your dimensions. I have one Aloris holder that I use, and my toolpost and most of my holders are Phase II. The one that fits the least well is the Aloris. It was also the most expensive and they supposedly invented the things--go figure. It is very tight and actually only fits one of the two "shoes" on the QCTP.
    Best,
    BW
  1. Quick change router bit
    By wjbzone in forum DIY CNC Router Table Machines
    Last Post: 06-07-2005, 06:56 PM
  2. Quick change tool system (milling)
    By mark c in forum Uncategorised MetalWorking Machines
    Last Post: 02-17-2005, 01:50 PM
  3. Quick change toolpost
    By Klox in forum MetalWork Discussion
    Last Post: 01-10-2005, 07:38 PM
  4. Quick change head design
    By kdoney in forum DIY CNC Router Table Machines
    Last Post: 07-05-2003, 05:57 PM
  5. Quick change bit holder
    By Laff Riot in forum DNC Problems and Solutions
    Last Post: 04-17-2003, 05:48 AM
