585,764 active members*
4,417 visitors online*
Results 1 to 9 of 9
    Sep 2006
    1738
    Taig way Lube...Question
    I'm stripping down my Taig CNC and going too re-adjust everything and fine-tune it all. Tram and lube everything...
    I know many people use Mobil1 oil for there ways on not just the Taig, but other machines.
    I checked in the garage, my brother has transmission oil for his old motorcycle, it says SAE75W
    Any chance this might work at all or am I better off getting the Mobil1 and what grade type. I plan on going too target or walmart later.
    -Jason
    Jul 2006
    887
    swing by a local machine shop and see if you can buy a gallon of waylube 68 from them. Guess what waylube is for................
    Sep 2006
    1738
    HAH ways
    But anyone else have info on that Mobil one stuff
    -Jason
    Feb 2007
    4553
    Talking Any idea what the viscosity of SAE75W is?
    Jason,
    Why not use this instead?
    http://zap.supergluecorp.com/pt26.html
    Teresstic SHP 680 might be a alternative also.
    Sep 2006
    1738
    Jalessi, thats glue...ZAP makes glue, i'm a hobbyist. I don't understand your post......
    -Jason
    Jun 2004
    6618
    He gets like that sometimes when he wiggles off his chain.
    He is implying that 75 weight is a little too thick.
    I use 30 weight oil. I had some Mobil 1 for a while, but ran out. It was good, but I couldn't tell the difference between it and regular stuff. Now I just use straight 30 weight non detergent.
    Lee
    Sep 2006
    1738
    I'll pick up some Mobil 30 weight. I have been using bad lube in the first place.
    -Jason
    103
    I've been experimenting with a ceramic waterproof grease on my ways and screws. It doesn't drip and won't get washed off by coolant. The jury is till out on wear reduction, but I have another Taig sitting in a box, just in case.
    So far, there has not been any binding that was related to lack of lube.
    Sep 2006
    1738
    Cool, thanks for the info
    -Jason
  1. Alarm (low lube,pressure) question
    By BMackinnon in forum Haas Mills
    Last Post: 05-31-2020, 12:53 PM
  2. re Spindle Lube and Lube Pump
    By robkuhi in forum Tree
    Last Post: 10-24-2011, 06:49 PM
  3. Quick Taig headstock question:
    By fretsman in forum Taig Mills / Lathes
    Last Post: 02-08-2008, 09:42 PM
  4. taig question
    By dfurlano in forum Taig Mills / Lathes
    Last Post: 05-10-2007, 08:13 PM
  5. TAIG spindle speeds and a load meter question
    By Smertrios in forum Taig Mills / Lathes
    Last Post: 04-26-2006, 10:34 PM
