585,555 active members*
3,324 visitors online*
    Jun 2008
    20
    the green button
    whats up with the green start button is all it does is turn it on or is there a way to link it with the cycle start button in the controller? sure would like it to start it after a tool change
    Apr 2006
    439
    The green button should probably be labeled "Power" and not "start" It just gives the control circut power.
    But this may help.
    I run a job that is a bunch of drill cycles. Change part, cycle start about every 20 seconds. I run hundreds at a time. I usually pull up a chair and sit in front of the machine. It was a real hassel reaching over to the control to hit the mouse button. So....I found an old PS2 mouse with a ball in the bottom and took the ball out. This mouse also had a real long cord. I fished it through the computer cabinet into the front cabinet. When I need it I just open the front cabinet door pull it out and set it on the table. I set the "Main mouse" to hover over the "cycle start" on the mach screen and leave it there. Now my "Remote mouse" is a left click cycle start button. With the ball removed it can't do anything else. When the job is done I just coil up the cord and put it on the shelf in the front cabinet. It has worked very well for me. Maybe it will fit your needs as well.
    Hope it works for you
    Scott
  1. New SX3 (green with a little rust red)
    By Yojinbo in forum Benchtop Machines
    Last Post: 09-13-2007, 05:10 PM
  2. Easy Being Green...& Your Job
    By fizzissist in forum Environmental / Alternate Energy
    Last Post: 05-22-2007, 06:15 PM
  3. green as they come
    By SILVERBACK in forum Charter Oak Automation Support Forum
    Last Post: 09-25-2006, 12:34 PM
  4. So New, I'm as green as a Martian
    By Micro Rotors in forum DIY CNC Router Table Machines
    Last Post: 09-15-2006, 12:22 AM
  5. green as grass
    By jonandyev in forum Stepper Motors / Drives
    Last Post: 04-19-2006, 07:04 PM
