584,841 active members*
4,402 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Haas rotary control and 5C indexer plug...how many pins?
    Dec 2005
    183
    I'm looking at a 5C indexer on ebay and wanted to buy a control separately. The indexer seems to have 14 pins and the controls I have seen so far have 7pins and 17 pins.
    Anyone know how many variations there are or how hard they might be to find? Thanks in advance.
    Oct 2009
    4
    Cable pinouts
    The 14 and 17 pin versions are similar. You can get adapter cables to run a 17 pin rotary with a 14 pin box & vice-versa. These are brush type servo motor versions. The 7 pin models are stepper type motors & the control/motor is not compatible with any other. If you cannot locate a used control box,try calling the Haas Factory Outlet in Allendale,NJ/NY. They may be able to help.
  1. Rotary table indexer
    By kwackers in forum Open Source Controller Boards
    Last Post: 02-20-2022, 07:19 PM
  2. Haas rotary/indexer controller protection
    By teal854t in forum Haas Mills
    Last Post: 02-02-2022, 08:30 PM
  3. Hardinge 5C Rotary indexer on FADAL'S
    By srmodelmaker in forum Fadal
    Last Post: 01-21-2008, 03:29 PM
  4. haas rotary control
    By heartlnd in forum Haas Mills
    Last Post: 02-04-2007, 09:46 AM
  5. HAAS Indexer Prodramming / Control
    By CAMmando in forum Haas Mills
    Last Post: 06-10-2003, 04:22 PM
