585,589 active members*
2,840 visitors online*
    Oct 2007
    38
    TL-1 power supply problem
    Haas Tl-1. I got an alarm for an X axis fault (161)when my machine rapid home for a tool change. I cleared the alarm and continued on with my program. When the machine rapid home for the next tool change I heard a loud pop, the spindle motor slowly wound down instead of breaking to a stop like normal, and it displayed an alarm for an OVERLOAD/ SHORT FAULT for the 320v power supply I believe the alarm code is 279. Also instead of an X axis fault this time there was a Z axis fault (163) along with the 279 code. Any guesses out there?
    Nov 2007
    1702
    Man, I haven't been on here in awhile. I hope you got this fixed. My TL-1 also had some weird problems. It eventually popped inside the power supply. They replaced the power supply under warranty. I was also having startup problems with it blowing the breakers in my panel. After replacing the power supply, no more problems.
    Greg
  1. How'd you supply your power supply?
    By cnczane in forum DIY CNC Router Table Machines
    Last Post: 08-28-2011, 11:13 AM
  2. Does anyone have stepper motor power supply problem?
    By david_geng in forum Syil Products
    Last Post: 09-04-2007, 07:02 PM
  3. ATX 2 power supply problem
    By flannman in forum CNC Machine Related Electronics
    Last Post: 05-28-2006, 07:19 PM
  4. Power Supply from a computer power supply
    By jmytyk in forum CNC Machine Related Electronics
    Last Post: 01-11-2006, 09:56 PM
  5. stepper power supply problem
    By bertvk in forum CNC Machine Related Electronics
    Last Post: 08-20-2004, 07:08 PM
