Originally Posted by
hkfanatic
ok im haveing a stupid beginner problem thats causeing my brain to melt.
im trying to cut a 180deg radius on the out side of a blocks sides
heres the blocks dimensions x 2.5 y 1.0 z 3.0
zero is in the dead center of the block.
im useing a 1.0dia endmill
heres how im programming it.
(starting at zero Assuming m3 and etc.. has been done)
N001 G0 Y-.938
N002 G01 Z-1.0 F2.0
N003 X1.250 (THIS IS WHERE THE ARC WILL START FROM)
N004 G03 Y.983 R1.001 (i want it to do an arc the same spot on the op side)
N005 G01 X-1.250
N006 G03 Y-.938 R1.001
N007 G01 X 0.0
so essentially it cut an oval shape into the out side of the block 1 inch deep
my machine acts like its a G01 cammand and doesent arc.
im not too proficiant at Gcode they only touched on it in school.
help!
thanks
N001 G0 X0 Y-.938 (Insert start position)
N002 G01 Z-1.0 F2.0
N004 G03 Y.983 R1.001 (Typo should be Y.938)
N005 G01 X-1.250
N007 G01 X 0.0
The best way to learn is trial error.
