586,000 active members*
4,862 visitors online*
    Jan 2006
    43
    Lightbulb Mach 2 / 3 VFD Spindle control
    Hello all
    Can anyone tell me where I can find a good schematic of a vfd spindle speed interface controler for Mach 2 or 3. I have converted an X3 to a belt drive ac motor and this is the last part of the conversion. Now I know you can buy them but am kinda a homebrewer. I have burned quite a few boards with pics, dac's and adc's etc.. but am not sure how to go about converting the digital io's / pwm to my hitachi sj200 vfd. It looks like there are two different methods for controling output speed/freq. 0 to 9.8 volts @ 10k or 4 to 19.6ma @ 250 ohm. Since I am not use to working with variable current designs. I think that the variable voltage route is the way to go, but I am open to any suggestions. Maybe even a microchip pic pwm capture and compare to dac would work. Any ideas...
    JpBinc
    Mills specs...
    X3 cnc'd, steppers, closed loop, ballscrews, gecko's, converted to belt drive spindle 3 phase 1.5hp metric 4 pole motor. 480ipm xy 300ipm z
    May 2006
    573
    Just by change you change your mind
    http://homanndesigns.com/store/index...products_id=38
    22$ isnt alot of money
    Jan 2006
    43
    After 3 months of designing and testing..... Your point is well taken! The only thing I didn't like about it is the resolution. Rpm / steps Not bad just not as fine as I would like.
  1. Replies: 0
    Last Post: 10-16-2007, 03:46 AM
  2. Can MACH generate +/- 10V to control SERVO spindle Drive?
    By cjchands in forum Mach Software (ArtSoft software)
    Last Post: 07-23-2007, 03:58 AM
  3. Mach Lathe - Spindle Control How??
    Last Post: 04-05-2007, 04:21 PM
  4. How would you use Mach to control a bender?
    By panozeng in forum Mach Software (ArtSoft software)
    Last Post: 10-18-2006, 06:40 AM
  5. Mach 3 no spindle - but OK in Mach 2
    By zcases in forum Mach Software (ArtSoft software)
    Last Post: 07-31-2006, 01:38 PM
