585,741 active members*
5,084 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > Trouble Machining Ball-screw End
    Jan 2007
    219
    Exclamation Trouble Machining Ball-screw End
    I am trying to retrofit my knee mill by replacing the old worn out screws with new ball-screws and ball nuts. I turned the end of the Y axis screw down to the same dimensions as the stock one, but when I tried installing it wit would wobble when turning. At first it wobbled almost 1/2". I then tried adding some material with the welder to create a shoulder to ride on the bearing race. This helped a little but not much. We later discovered that the threads weren't perfectly straight on the screw, because we had to use a die to make them, because the auto-feed on the lathe is broken. So, I cut the screw back some more, cut the old threads off and redid them. This time we used the tailstock to push the die and keep it straight. This seemed to work very well. I then tried it again, but it still wobbled. We then tried adding material again with the welder to create the larger shoulder again. This time we filled the gap in the threads and went around an extra time to make the shoulder taller. This seemed to help even more but still not perfect. I then cut the back of the nut on the lathe to make it perfectly perpendicular to the screw. Also helped a little but still not perfect. So now I am stuck and dont know what to do.
    Is there anything I can do to make this screw work? Or should I buy another and bring it to the local machine shop?
    Using a dial indicator on the threads of the screw, I measured the High and low spots in the screw. At the low the dial read .0085" and at the high it read .048", diving a difference of .0395" out of wack.
    Anybody have any ideas?
    -Adam
    Picture 1: Screw with Weld before being re-turned
    Picture 2: Screw after being re-turned
    Picture 3: Dial Indicator showing low position
    Picture 4: Dial Indicator Showing High Position
    Picture 5: Dial Indicator Setup
    Picture 6: Back of bearing mount with shoulder on inner race
    Picture 7: Front of bearing mount with nut on inner race
    Attached Thumbnails Attached Thumbnails IMG_0620.jpg   IMG_0622.jpg   IMG_0625.jpg   IMG_0626.jpg
    www.adambrunette.com - Converting My Harbor Freight X2 And My Jet Jvm-830 Knee Mill, As well as many other projects.
    Dec 2007
    10
    Hi Adam!
    Is it possible that because of the welding of the shoulder the material of the ball-screw has softened? It could also be that your spline has a banana-shape (exaggurated), as a result of the welding. Try to verify it with a dial. If this is the case, you need a new ballscrew... :-( If it has to be machined, try preturning with a low speed. Best to grind it after turning.
    Good luck!
    Geert Molema (Netherlands)
    Feb 2007
    158
    What does the other end of screw ride in?
    I hate deburring.....
    Lets go (insert favorite hobby here)
    Dec 2007
    10
    Support
    Supporting the end of the ball screw with a simple 6003Z SKF ball bearing should be sufficient on most machines. Make sure it is aligned correctly. But if the ball screw keeps wobbeling, it has to be a banana... Check it with your dial.
    Try www.kuroda.com for examples.
    Good luck!
    Jan 2007
    1389
    the proper way to machine a ball screw is to CUT a set of softjaws for your lathe. also cut a piece of material to support the back end of the ballscrew in the tube of your mill.
    if you dont support the back you will never get it right unless you use 8"-12" jaws.
    if the ball screw is small enough you can use a collet in the front but still support it in the back.
    all that will get you close( with in a few thousandths)
    if the ball screw came with ground journals than you can indicat off of those right next to the threaded part. they are usually close but not perfect.
    The dial indicator you have isnt a good idea to use as cause it will be thrown off when when you turn the ball screw by side play. ( those type of indicators are made for up and down only not rotation) use the other type. however if you only have that indicator get some oil and oil the ground shaft good so the indicator tip runs on something smooth with no friction.
    you should also check the threads on the high and low spots (root) to see if the thread is indicated in) shimming may be requiered.
    the best thing to do is center drill the end of the ball screw then run a center in it and recut your ods and faces.
    oh yeah that one pic were your indicator is on, that numbers you are getting are bogus and you can't check run out that way so ignore it, you have to support each end in order to check run out, supporting one end in a bearing set wont do any good either as the bearing will not support the ball screw perpendicular.
  1. Machining Ball screw ends
    By Ferrari2007 in forum DIY CNC Router Table Machines
    Last Post: 05-06-2008, 01:30 PM
  2. what bearing fit with acme screw 1/2 -10(for cheap ball screw)
    By apex in forum Linear and Rotary Motion
    Last Post: 07-27-2007, 05:15 PM
  3. machining ball screw
    By KEYTEEM in forum Linear and Rotary Motion
    Last Post: 08-30-2006, 12:27 AM
  4. Machining the ends of ballscrews & ball screw size
    By Zumba in forum Linear and Rotary Motion
    Last Post: 02-15-2006, 05:47 PM
  5. New technology.... old debate.....ball screw vs lead screw
    By trubleshtr in forum Linear and Rotary Motion
    Last Post: 08-16-2005, 02:42 AM
