Does anybody have the Fanuc 12M's parameter list?
which option are you looking for?
chris.
If its the general parameters, the maintenance manual lists the general parameter value options.
If you need specific values, then you need someone with the identical machine.
Also you will need the 9000 Option parameters.
Al.
Albert E.
The machine is OKK MCH600,I don't have the maintenance manual for this machine.Can i copy the general and specific parameters of the machine with same model OKK MCH600 but with Fanuc 11M?Does anybody send me the 9000's option parameter of Fanuc 12M for any vertical milling ?I think i need them to run the machine fisrt.
Thank for any help
E_mail :[email protected]
You should be able to use 11M parameters for 12M as long as they come from the same model machine.
I wonder if the 9000's option parameters are the same?
Can anybody send me a typical 9000's parameter of 12M?
