585,991 active members*
6,624 visitors online*
Page 1 of 3 123
Results 1 to 20 of 41
    Nov 2004
    321
    Atlas horizontal MI mill
    Can someone tell me where can I find instruction manual & illustrated parts manual for Atlas horizontal MI mill.
    Jun 2006
    2512
    Have a look here:
    http://www.lathes.co.uk/manuals/
    - MA743 ATLAS MILLING MACHINE
    Phil
    Quote Originally Posted by toneV8 View Post
    Nov 2004
    321
    I want to convert this mill to cnc.
    I remove horizontal head and planned to put steel tube and router see pic.
    What kaind acme ( trapezoidal ) screws and stepper motors ( torque ) to use.
    Can someone recommend something.
    Nov 2004
    321
    Can someone help me with this.
    I want start with conversion to cnc.
    Sep 2006
    1738
    It's not too complicated. You may want too make the head base from a casting. But thats more complicated.
    I can see some big large steel beams being used and mounting everything together that way.
    How do you plan on surfacing the cut part too have the new head mounted precisely?
    -Jason
    Nov 2004
    321
    First I want convert 3axis to cnc and after I will see how to mount head together.
    Now I need to know what kaind acme screws and stepper motors to use ( how much torque do I need for milling aluminium, brass, copper, plastic, wood). Is it Ok to use acme screw with more starts or acme screw with more starts is not good for milling aluminium.
    Original acme screw is 1/2 but I will like to use 5/8.
    Sep 2006
    1738
    ToneV8- I was thinking originally the same thing. I would keep the the head the way it is and modify that for spindle. Not the whole head assembly.
    I would do 5/8 for CNC. As far as torque goes, I'm not sure in your case, because factors of your table weight, ratios all come into play. I'm not sure how big your mill will be, but I can see something being in the 700 Oz range...Just an estimation.
    -Jason
    Jul 2007
    28
    This fellow sells a good manual for the machine...
    http://www.ozarkwoodworker.com/item/...gparts-manual/
    This is interesting, as the base, knee, and table castings are often available from parted out machines on ebay.
    I am surprised that more people haven't used these for a start point on a build.
    The advise to use the head as is, with gearing to change the spindle speed is a good one. There are horizontal to vertical heads, that mount on the overarm available (but rare) already.
    Luck
    Mike Horne
    Nov 2004
    321
    The table is approximately 18''x4,5'' Z axis 6''
    My mill is not bigger then Sieg X3 mill.
    People who have Sieg X3 mill use X,Y axis 425oz for Z axis 600oz.
    Can I use 425oz for my mill.
    Sep 2006
    1738
    Oh yea, you should be fine. I thought it was much bigger.
    -Jason
    Jul 2007
    28
    For the motor lifting the knee and table, you may well want to go with a larger motor as the x3 does for the head.
    Not many people are modifying this machine, as far as I can tell, so there is not going to be too much info out there.
    So, if you convert to ball screws, you may be one of the first to do so.
    I have one of these, mostly in pieces so I'll be following what you do
    Mike
    Nov 2004
    321
    There are no space for ball screws. Nuts are to big to put under table.
    Jul 2007
    28
    Maybe you could use two nuts at either end of the table, on the outside, under the little tray type extenders seen on some machines.
    Bulky, but not under the table.
    On the y (front to back) the nut could be on the outside of the saddle.
    If your machine is whole, then on ebay the prices for an atlas in good condition are enough for you to cash it in for an x2
    Nov 2004
    321
    For now I don't plane to sell mill.
    Mill is dismantled because I start to repair mill, cleaning......
    Electro motor is 220V/380V 0,355kW see pic
    Tomorrow I will take picture of each part.
    Nov 2004
    321
    pictures
    Attached Thumbnails Attached Thumbnails IMG_15490101.JPG   IMG_15500101.JPG   IMG_1551010101.JPG   IMG_155284080408.JPG
    IMG_1554804804.JPG   IMG_1555804084.JPG   IMG_15568408048.jpg   IMG_155780480408.jpg
    Nov 2004
    321
    pictures
    Attached Thumbnails Attached Thumbnails IMG_15628048088.jpg   IMG_15638048408.jpg   IMG_156480484.jpg   IMG_15650484048.JPG
    IMG_1566840848048.JPG   IMG_1567848048084.JPG   IMG_156884808408.JPG   IMG_156980408408.JPG
    Nov 2004
    321
    pictures
    Attached Thumbnails Attached Thumbnails IMG_15768048048.jpg   IMG_1577804848048.JPG   IMG_15788048804048.JPG   IMG_157980480488.JPG
    IMG_158084808404840.JPG   IMG_1581804804048.JPG   IMG_15828048480.JPG   IMG_15838048048.JPG
    Nov 2004
    321
    pictures
    Attached Thumbnails Attached Thumbnails IMG_158880484808.JPG   IMG_15978048048.JPG   IMG_159880480484.jpg   IMG_160080480448.jpg
    IMG_160180484018.JPG   IMG_1603840801515.jpg   IMG_16040484008.JPG   IMG_160680480480.JPG
    Nov 2004
    321
    pictures
    Attached Thumbnails Attached Thumbnails IMG_16158048084.JPG   IMG_16168048048.jpg   IMG_161780488048.JPG   IMG_16188048044.jpg
    IMG_16200484804808.jpg   IMG_1621804804880.jpg   IMG_162584804804.JPG   IMG_1627840804808.JPG
    Nov 2004
    321
    pictures
    Attached Thumbnails Attached Thumbnails IMG_1631804804848.JPG   IMG_16368048051.JPG   IMG_16408048084.JPG   IMG_16428048048.jpg
Page 1 of 3 123
  1. B axis for horizontal mill OM
    By nabil_elbadri in forum Fanuc
    Last Post: 12-09-2016, 08:38 AM
  2. OKK horizontal cnc mill HMA460
    By bum1033 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 05-21-2008, 02:18 AM
  3. Atlas Knee Mill Way Cover
    By olf20 in forum Knee Vertical Mills
    Last Post: 09-27-2007, 01:31 AM
  4. Horizontal Mill Management
    By Metalman97415 in forum MetalWork Discussion
    Last Post: 08-16-2007, 12:11 AM
  5. Help with Horizontal Mill Programming
    By MAX RPM in forum Mechanical Calculations/Engineering Design
    Last Post: 06-21-2006, 04:18 AM
