Did some reading on the machine. I don't think that they were using a "G20" son the machine is running in the "default" mm. I have the guy looking at getting the software. The program does not look to hard to run but when you run pro engineer everything else seems easy? I think I should be able to get everything setup and online without doing much re-configuring. I will change the config to a "G20" and get the program figured out. The people with the program said the have a post for mach3 so it should be a piece of cake. I like the way the mach3 works as well. It has things that took me hours in other shops to build into the controller. The pre-configured stuff looks cool.
