Hello,
Can a 15 Amps. cont. AC servo drive work with a 19 Amps. cont. AC servomotor? I think the answer is really simple, but I want to be shure.
Jorge
Hello,
Jorge
The current limit of the drive is probably going to limit the maximum current the motor is capable of, so the Current ( motor torque) output will be proportionally lower.
i.e. the motor will not be able to reach the maximum torque it is capable of.
Al.
Albert E.
Al,
Please tell me if I am correct. The servo motor needs 19A to get a cont. stall of 13.3NM. The motor has a Motor torq constant Kt NM/A of .68. So if i use a 15 Amps cont. drive I get 15*.68= 10NM Cont. stall?
And if Peak stall of the servo motor is 27.36NM, what would it be with a 15A , 30A peak servo drive? Would the peak trq NM be 30*.68=20NM
I`m asking all this because I want to retrofit a Mazak Lathe. I already have one with dynapath and Baldors, But now I want to use drives and motors I have already and buy a Mazak Lathe with a death control.
The one that is retrofited have 6.5NM motors,with peak of 18.98NM; so If this work at 10Nm, with peak of 20NM, would be great.
Jorge
I have always considered the peak torque as not a usable torque value, this is generally the maximum current that would occur at the point of demagnetization.
So if you have drives set with a suitable current limit, your motors should ideally never see this figure.
You can calculate your constant torque as you show based on the Kt Nm/amp.
Al.
Albert E.
