585,942 active members*
3,345 visitors online*
Thread: Mach4?
Results 1 to 8 of 8
    Apr 2008
    36
    Mach4?
    When I open an art file with Corel Draw 12 and save as a *.dxf and imported to Mach3 it says that it is a Mach4 file...How can I open it with Mach3? thanks for any imput...
    Feb 2007
    4553
    Are you using LazyCam to open the DXF?
    Jeff...
    Apr 2008
    36
    Not using Lazy Cam as this feature it is only found on new Mach3 versions.
    Feb 2007
    4553
    Smile
    Angel,
    Mach itself wont process a DXF, you need to process the DXF in LazyCam or some other Cam product that will output in Gcode.
    Then input the Gcode into mach3 and output to your cnc machine.
    Jeff...
    The older versions of mach3 can have a .dxf converter. You access it under File > .dxf import or something like that.
    Are you saying when you try to import the .dxf file, it gives you an error? Can you post a screen shot of this error? And can you post the .dxf here?
    Feb 2007
    4553
    Smile Sorry for giving bad information.
    You might want to check in with the Mach support forum.
    http://www.machsupport.com/forum/index.php
    Jeff...
    Aug 2019
    5
    hi
    jaiessi can you sugwss me to find mach4 cracked version
    Aug 2019
    5
    how download mach 4 full version becuse its soo expensive can any sugees where i find full version.
  1. G100 firmware with Mach4
    By efrem in forum Mach Software (ArtSoft software)
    Last Post: 10-12-2006, 02:51 AM
  2. Mach4 & gecko g100
    By efrem in forum Machines running Mach Software
    Last Post: 07-14-2006, 07:17 PM
  3. Mach4 and G-Rex
    By Death Adder in forum Mach Software (ArtSoft software)
    Last Post: 04-20-2006, 07:23 AM
  4. Not sure if this is a Mach4 question or G-Rex
    By srbliss in forum Mach Software (ArtSoft software)
    Last Post: 03-14-2006, 01:33 PM
