584,846 active members*
4,502 visitors online*
IndustryArena Forum > CAM Software > Vectric > Post Processor for Prototrak
Results 1 to 11 of 11
    Mar 2008
    108
    Does anybody have a post for an mx3 Prototrak retrofit?, can't seem to get anything to work.
    Scott
    Nov 2005
    1468
    I think I can help. I got these:
    M-MX3.PPR
    M_MX3E.PPR
    M_MX3EDF.PPR
    M_MX3EZF.PPR
    M_MX3PRO.PPR
    Are any of them any good for you? is so PM me please and I'll E-Mail them.
    I'm running a Protrak A.G.E 2 with an MX2 Post so I dun know if the MX3 Posts is the same directory will work, but I think they should?
    You say that you "cant seem to get anything to work". When you go to Post Process how far does it get? Any error messages? On mine it sticks the Post Processed file in the C:\MYDRAWINGS folder, I need to rename the file numericaly (like 12345.CNC) for the Protrak to recognise it when I transfer it to the Mill- it won't recognise alpha characters, only numbers as a file name.
    Gimme a shout if you want the files!
    I love deadlines- I like the whooshing sound they make as they fly by.
    Mar 2008
    108
    I'm not sure which one might work but I'll give all of them a try if you don't mind. I will pm you my email address.
    I haven't had any luck getting tool paths to the mill, if I create a program with Prototrak, I can save it my PC but gets corrupted if I have more than a few events programmed.
    Tony from Vectric sent me a couple of posts but none were reccognized by Prototrac, if I look at the text that they each create, I get
    Prototrak example
    GXXX
    G45
    Gdfrr
    and so on
    Vectric post example
    G45 G67 G32 G98 and so on
    Scott
    Nov 2005
    1468
    E-Mail sent
    [edit]Argh! I just noticed that your software isn't the same as mine. I've sent the files anyway since I said I would. If anyone else has the correct post processor can they please send it to him.
    Sorry for the hassle man, genuine mistake.[/edit]
    Aug 2005
    597
    Hi Scott,
    I have requested more information from ProTRAK and will let you know what they say.
    Tony
    Aug 2005
    597
    Hello Scott,
    I spoke to XYZ Machine Tool who are the manufacturer of the Protrak controller (I think) and they said you should be able to import GCode toolpath files. This is an Advanced Feature - cost option for users outside the UK - but they thought it was a standard feature for users in the US.
    You should be able to check on the machine by doing the following,
    Inside the program selecting > In / Out > List Supported Types and there should be a *.GCD option (this is the file type saved from the Vectric software)
    I hope this helps,
    Tony
    Mar 2008
    108
    Quote Originally Posted by Tony Mac View Post
    Hello Scott,
    I hope this helps,
    Tony
    Southwestern Industries are the guys that make Prototrak. I will look to see if it will take a .GCD, I think it will only take an .mx3 or .cam though.
    Mar 2008
    108
    Quote Originally Posted by ImanCarrot View Post
    E-Mail sent
    I got the files, I'll give them a try anyway, maybe they will work. I really appreciate you trying.
    Scott
    Aug 2005
    597
    Quote Originally Posted by NJC View Post
    I talked to the guys at Southwestern Industries and they said yes the controller will open GCode files - and also told me to contact the guys in the UK for confirmation.
    The GCode toolpaths can be saved as either .GCD or .CAM files these are simply file extensions to the name and the content is the same.
    Tony
    Oct 2008
    33
    mx2 files
    I'm in the same boat as the rest of you. I can't get any files to open even the ones that were on the floppy that came in the machine. It is a Chevalier FM32 with a Proto-Trak M2 system. I'm afraid I've tried so many different programs and extensions that nothing will work. I downloaded a trial of Part Master and I did find the MX2 extension and saved a file but the darned thing wouldn't open. Does anyone have the procedure from start to finish to run a DXF file through the post processor?
    Thanks in advence, I hope,
    Jim
    PS I also bought the full version of CUT2D and it works slick. Too bad I can't use it!
    Oct 2012
    A couple prerequisites I noticed on our machine: You need to have a "Programs" folder on your USB, from where the programs to be read need to be loaded. File names as mentioned need to be numeric only, I use the file extension .CAM (ex: 1234.CAM). On ours I use the Service Code "341" to copy the files from USB to the controller.
    Hope this is helpful?
    Jazzed
  1. Where can i get a processor for solidcam to prototrak?
    By 190773 in forum Uncategorised MetalWorking Machines
    Last Post: 02-27-2009, 03:13 PM
  2. need a prototrak mx2 post processor
    By peezweez in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 04-02-2008, 10:25 PM
  3. Fanuc 6M Post Processor for ProtoTRAK MX2
    By Gordonv in forum OneCNC
    Last Post: 11-16-2007, 08:07 PM
  4. prototrak plus post
    By wallyman in forum Post Processors for MC
    Last Post: 05-30-2007, 03:33 PM
  5. Need post help for a Prototrak DPM-V3
    By Shadowfaxx in forum Post Processors for MC
    Last Post: 11-01-2004, 10:21 PM
