585,743 active members*
4,912 visitors online*
Results 1 to 6 of 6
    May 2008
    72
    Fanuc 0i-MC absolute arc center
    Is there a way to change my control parameters so that it always reads in arc centers as absolute. This is on a 2007 0i-MC control.
    JP
    Apr 2007
    148
    Quote Originally Posted by PinnacleMachine View Post
    JP
    I just looked through my parameter manual and I didn't find anything related to what you want to accomplish. Maybe there is a work around for ya, tell us a little more about what you are trying to do and maybe we can help.
    May 2008
    72
    The problem I've been having is that my control says there is an arc end point tolerance issue. My arc end point tolerance Parameter 3410 is set to 100 (=0.001"). In my cam software I can post arcs either abs or inc and with it posting in abs it is easier for me to work out on paper if there really is a problem. To get around the tolerance issue I just set Parameter 3410 to 0 to turn it off - my parts came out just fine.
    JP
    Apr 2007
    148
    JP
    Cool, so it sounds like you solved your issue or at least found a work around, see I knew I could help
    2932
    Fanuc's use incremental arc-centers. Is your CAM system outputting X, Y, I and J to 5 decimal places? You could also (possibly?) set your CAM system to output the radius (R) of the arc, rather than the centerpoint (I,J).
    May 2008
    72
    Quote Originally Posted by dcoupar View Post
    I've just bee posting to 4 decimal places - should I change it to 5? I can also change my post to output R rather than I,J
    JP
  1. Fanuc 11-T CNC lathe center programcode
    By manoharan in forum MetalWork Discussion
    Last Post: 08-24-2008, 06:33 PM
  2. Replies: 2
    Last Post: 08-22-2008, 05:14 AM
  3. Replies: 4
    Last Post: 08-06-2008, 04:03 AM
  4. Fanuc 11M Absolute position probs
    By trotsky in forum Fanuc
    Last Post: 11-05-2007, 08:29 PM
  5. How do we get absolute to Zero??
    By Fine01 in forum Fanuc
    Last Post: 10-23-2007, 02:55 PM
