585,764 active members*
4,005 visitors online*
Results 1 to 9 of 9
    Jul 2008
    5
    Mitsubishi FR-SGJ Spindle Drive
    I have a faulty Mitsubishi FR-SGJ-2-1.5K Spindle Drive, from a Traub TNL16, that’s giving an alarm 24 (main circuit fault).
    I've fitted a replacement drive & the machine is OK so I know the problem is on the original drive.
    I've visually checked the drive over & there's nothing obviously blown.
    Does anyone have a Troubleshooting Manual for this drive they could e-mail me or a link to one?
    Mike
    Jun 2008
    150
    http://www.meau.com
    nav to downloads
    click manuals
    select for division-cnc
    family=spindle amp
    series=fr
    manual type = maintenance
    select your manual
    Sorry I couldn't link you straight away, tried but it wouldn't display the manuals.
    Jul 2008
    5
    Hi Leelund,
    Many thanks for the info.
    Noticed this link on a few other posts for Mitsubishi but could never get into it, was always re-directed to the Melfans site.
    Last night I found an old post, by Gridley51, with info on de-activating IE active script & have now been in & got the maintenance manual downloaded.
    Turned out to be perfect timing as we had a problem with an FR-SF drive this morning that popped a 35A supply fuse. I've had this in the past & replaced the fuse & got fireworks when I powered back up!
    At least today I was able to download a troubleshooting manual & carry out checks on the diode stack & transistors etc to prove the drive was OK.
    I meggered the motor & cable & all was OK so I replaced the fuse & we're back in business.
    I’ll check out the FR-SGJ manual & let you know how I get on with the drive.
    Mike
    Nov 2006
    925
    Mike,don`t know if you are aware,but Mits in Europe don`t support some of the Fr drives and if they are on a Mazak they won`t even talk to you.You can get around this by talking to Mits in the States.They are not very good at emails but excellent on a phone call.
    Mark.
    Jul 2008
    5
    Mark,
    Thanks for the info.
    No Mazaks here but have 11 Traubs & they’re all Mitsubishi.
    It’s the same situation with Mits Europe, they won’t talk to you, you have to go to Traub.
    Traub will only supply a complete drive, on service exchange, you can’t order individual boards/components.
    I’ve never tried calling Mits in the States, I presumed they’d just give me the brush off & tell me to call Mits in Germany or go to Traub.
    Is there anyone in particular that’s best to deal with?
    Have you been able to buy boards/components from them or do you have other sources?
    Mike
    Nov 2006
    925
    Mike,I`ve sent you a PM.
    Mark.
    Jul 2008
    5
    Mitsubishi FR-SGJ Spindle Drive - Alarm 24
    Finally got back to this last week.
    I'd swapped the front card, SGJ-CB, with another drive & the fault followed.
    Took the card off & just went through the components with a meter doing simple resistance checks, found resistor R61 open circuit (680Kohm 3W).
    Got resistors in on Monday, soldered one in & ran the machine on MDI at various speeds for 24hrs & all OK.
    It's been back in production since yesterday afternoon & OK so far.
    Nov 2006
    925
    Hi Mike.
    Are you still on the same email address?
    Mark.
    Apr 2010
    Quote Originally Posted by mikwest View Post
    Hi Leelund,
    Mike
    Hello Mike,
    I'm looking for datasheet and electronical shema of FR-SGJ and FR-SF, I have some problem with spindle drive (NC EMERGENCY) after power-off from network, and need more info to solve problem. Could you link me where to find some data about FR-SGJ? I checked on http://wwwf2.mitsubishielectric.co.jp/english/ but it is not available.
  1. mazak mitsubishi spindle drive
    By intermax in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-30-2014, 05:44 PM
  2. Mitsubishi spindle problem
    By wcopley in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-03-2013, 08:58 PM
  3. Mitsubishi spindle motor
    By dovi in forum Mori Seiki lathes
    Last Post: 03-13-2008, 01:26 PM
  4. Mitsubishi MDS spdl. drive parametrization.
    By GPena in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-19-2007, 09:36 PM
  5. mitsubishi spindle servo drive
    By intermax in forum Servo Motors / Drives
    Last Post: 11-03-2006, 04:15 PM
