585,991 active members*
6,480 visitors online*
IndustryArena Forum > CAM Software > Mastercam > 2D Contour on a round OD not very round :(
Results 1 to 6 of 6
    May 2007
    155
    Im getting huge flats on the OD of the Contour
    with .001 tolerance filtering is tunrned off ...
    I cut a Pocket in the same part with the same tolerance and its super smooth..
    What did I miss ? is the model bad?
    MC9 part
    solid Model or surface model? are you cutting an arc or a spline?
    Steve
    www.cad2cam.net
    www.cad2cam.net
    Programmer/ Certified Cam Instructor
    Nov 2005
    174
    Did you import the model or create it in MCX.
    May 2007
    155
    Quote Originally Posted by rickyt View Post
    I imported it from RHINO ...
    and the mesh settings were set very low ...
    But only one part of the part machined crappy .. the other holes and round bosses cut great .. just the oD of the part was tiny lil flats like 100 of them
    looks cool just not smooth ...
    Apr 2003
    3578
    so when you check screen Statistics what do you have surfaces or solids lines and arcs or splines. when info to help figure out what happened.
    If you share the MC file this would help you.
    Cadcam
    Feb 2006
    19
    Quote Originally Posted by kojack View Post
    I've had this happen a few times in the past, when machining an ellipse. On all of the elliptical or spline ID features, the part was great, but on the OD, it would look just as you described.
    I can't remember 100%, but I'm pretty sure the easy work-around was to just chain the OD in the reverse direction (so the tool wants to be on the inside of the chain), then offset the XY direction the same amount as the cutter diameter so the tool ends up back on the correct side of the part. It sounds wacky, but I'll be damned if it didn't solve the problem every time. Very bizarre.
  1. A round bar question!!
    By cyntanada in forum Mechanical Calculations/Engineering Design
    Last Post: 02-24-2008, 03:23 PM
  2. Out of round on last cut
    By Robin Hewitt in forum Benchtop Machines
    Last Post: 08-18-2007, 01:20 AM
  3. round and round we go
    By omegaghost in forum Benchtop Machines
    Last Post: 01-10-2007, 05:25 PM
  4. Round Numbers
    By stampman in forum Fanuc
    Last Post: 09-06-2006, 12:12 AM
  5. round ram head
    By locoind in forum Bridgeport / Hardinge Mills
    Last Post: 04-21-2006, 03:44 AM
