585,981 active members*
4,307 visitors online*
    6855
    Accuracy problem with pocketing
    I pocketed a piece of alum the other day, I used deskcnc and ran it on ya. The problem is that the cut out was .050 to small, I check the g-code and didn't find a error, I check the machine my doing a incremental jog once again it was on the money in both the X and Y. What could have cause the error in the cut? I really thinks it's a YA bug and one have this happen?
    Oct 2003
    263
    If you checked the code, maybe the cutter was smaller than you thought, or pushed off (seems unlikely it would be that much, though). Did you use cutter comp and maybe offset it the wrong way?
    Software For Metalworking
    http://closetolerancesoftware.com
    6855
    Nope that's the obvious and the cutter was right on. I even re-ran the file and still got the same result, the only thing I did not turn on was constant vectoring.
    4826
    Can you force the error larger or smaller depending on the size of the pocket? If you post your file, we could maybe backplot it for a second opinion. I guess we'd need to know the part dimensions, too.
  1. Ballscrew Basics
    By Swede in forum Linear and Rotary Motion
    Last Post: 04-05-2024, 08:10 AM
  2. Okuma LC-20 Threading problem
    By Gunner in forum DNC Problems and Solutions
    Last Post: 12-14-2011, 05:11 AM
  3. Stepper RPM and Accuracy Question. Please Help!
    By David Bord in forum Stepper Motors / Drives
    Last Post: 05-25-2005, 08:27 PM
  4. CNC gantry Machine shows problem
    By Alex S.A in forum DNC Problems and Solutions
    Last Post: 04-25-2005, 09:02 PM
  5. Fadal VMC4020A axis problem
    By cwww in forum DNC Problems and Solutions
    Last Post: 12-02-2003, 06:07 AM
