585,926 active members*
3,853 visitors online*
Results 1 to 17 of 17
    Aug 2008
    13
    Help! I need some expert advice!
    I am having a 24 x 36 x 12 machine being built that I will be using to cut electric guitar bodies and necks. It is being built with nema 34 670oz. stepper motors, 20mm linear rail on all axes, and the cutter will be a hitachi m12vc (midsized router). The builder is suggesting that I go with 3/8" 16 tpi lead screws. I am wondering if this is the best lead screw to use? Is the 3/8" too flimsy for this size machine? What would be my best bet as far as lead screw? Thanks in advance for any input.
    Also would like to say that this place is great and I have already learned quite a bit from other posts!
    sounds like he wants to use ready rod
    your motors will twist the screw into a pretzel , i have stainless screws , the one end was turned down to 3/8" . the x axis with a 1145 oz motor eventually twisted and broke the 3/8 dia , that was only a 1.5" length that was 3/8 on the 3/4" screw.
    over the distance you have, you will destroy those screws in no time
    if you going to use a cheaper type of leadscrew i would suggest using a 3/4-6 acme which is my preference diameter or a lot of guys are using 1/2-10 4 start acme
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
    Aug 2008
    13
    Thanks for the reply. That was my hunch. I'm not sure why he's suggesting an underated lead screw - the rest of the machine is beefy. What is my best option for a lead screw? If it means spending a little more that's fine. I don't want to skimp on a vital component.
    sounds like your building such nice hardware into it , have you concidered ballscrews , they are pricey but would work bautifully with the type of gear your using , and really if your going to be doing long runs and making money from it then it would be a small price to pay for the piece of mind
    Aug 2008
    13
    The builder actually offered ballscrews as an option. If I were to go that route than what would be an appropriate type of ballscrew for the size of my machine?
    it would depend up on the resolution you want to have , and the rest will be determined by the number of steps your motors and drivers will put out , theres two ways to go , high resolution lower speed , higher speed and lower resolution ,
    for eg. the screws i use are 3/4 10 start screws (not ballscrews) ,they are
    2"/ revolution so i get .001 resolution/step ,which is good enough for what i need my machine to do , but with that comes the speed , i keep my machine set at a conservative 500ipm and i dont need to wait on slow rapids and retracts , its all dependant on what you feel is good enough , the thing to take into concideration is what you will be cutting , do you need .0001 resolution for wood ?
    Aug 2008
    13
    So many choices....... My head hurts. I'm thinking that I will stick with lead screws. It looks like I just need some more "meat" so 3/4" looks like the way to go. So perhaps 3/4" 10 tpi. But how many start? You mentioned that you are using "3/4 10 start". Do you mean 3/4" 10 tpi? How many start?
    Quote Originally Posted by losgetlost View Post
    mine are 10 start , 2 inches travel per revolution , i got them from ebay so i have no clue of who sells them
    on my sons machine we used 3/4-6tpi single start acme from fastenal which work pretty good
    Go with 1/2-10 5 start acme. Most users here find that it gives the best performance for the price.
    Jul 2008
    55
    I bought the 12-10 5 start and my machine is roughly 5' X 3'.
    Aug 2008
    13
    Spoke with my builder this morning. I'm going with 5/8" ballscrews. He pointed to the fact that if I ever want to machine any of the hardware for my guitars (ie. guitar bridges) that the extra precision that the ballscrews give would be ideal. Thank you everybody for your input.
    Dec 2006
    90
    12" of Z
    With a 12" Z axis aren't you concerned about losing a great deal of accuracy? There are some huge moments of force there to contend with. Even industrial machines seldom venture into that territory.
    Aug 2008
    13
    Honestly I'm not sure. The build of the machine is almost identical to the K2-CNC MODEL KG-3925-G which is offered at 8" of z. Does anyone have any input on this. Will that extra 4" of z cause me to lose accuracy?
    Nov 2006
    226
    Quote Originally Posted by gerryv View Post
    Agreed. For rigidity, I wouldn't venture beyond 6". I think this may be a major problem...Why do you need 12" to cut guitar bodies? Are they machine out of a solid piece of wood? and if so, they aren't really 10"+ are they?
    Nate L.
    Aug 2008
    13
    Point well taken. I spoke with my builder yesterday and we are going with 6" of travel. Now I am looking at minimizing backlash. He claims that backlash will be minimal for what I will be using it for and can be adjusted in Mach 3 anyway. Right now he will be using Thomson (precision rolled) ballscrews and nuts. The nuts are not the anti-backlash type. Should I consider anti-backlash nuts for my purposes? Will I need the added accuracy? What would be the difference in price?
    Software backlash compensation is a poor fix and doesn't always work well. Getting rid of backlash is a much better choice.
    I've never used them, but have heard that some of those nuts can have quite a bit of backlash. Typically two are used together to get rid of the backlash.
    Jun 2008
    1082
    I'm a beginner too, and I also looked at the Thomson 5/8 ball screws. I've since gone with a seller on eBay (), but here's a couple links to the store I was looking at the hardest...
    Non-preloaded single ball nut ~$25
    Preloaded double ball nut ~$175
    That's for a single nut... :/
  1. CAM Expert
    By Jan in forum Uncategorised CAM Discussion
    Last Post: 07-24-2017, 08:37 AM
  2. Help - Need some expert advice
    By nosplinters in forum Benchtop Machines
    Last Post: 06-28-2007, 11:20 AM
  3. Looking For An Expert!
    By chipslinger in forum Daewoo/Doosan
    Last Post: 11-18-2006, 08:41 PM
  4. Q-Cad Cam Expert
    By Kevin Moore in forum Uncategorised CAM Discussion
    Last Post: 11-09-2006, 06:05 AM
