585,741 active members*
4,989 visitors online*
Results 1 to 10 of 10
    Jul 2007
    orientation mag sensor
    Desperately trying to locate a 2nd hand
    Fanuc magnetic orientation sensor.
    Possibly out of a retired machine being broken down for spares.
    We dont require the amplifier just the sensor.
    P/N A57L-0001-0037.
    regards
    Matt
    Jun 2003
    70
    A57L-0001-0037
    We have the sensor but need the preamp!
    Jim
    Jim Short
    www.tahlinc.com
    Sep 2004
    209
    I have an old sensor and pre-amp that I removed when I replaced the spindle motor and drive with different units. Spindle orientation was working prior to the retrofit, so I assume that the sensor and the pre-amp are both functioning.
    Unfortunately, neither have any identifying marks. The decal on the pre-amp has long since lost all of it's text and the portion of the decal that contains the part number on the back of the sensor has been rubbed off by the mounting bracket.
    If you're interested, snap a few pics of what you have and send them my way for comparison. Also, the orientation PCB in my machine was an A20B-0008-0030/02 unit; if you have the same PCB, there's a good chance that your sensor is the same.
    Chris Kirchen
    Jun 2003
    70
    A57L-0001-0037-C
    The sensor is for a Kitamura Fanuc OMC.
    Jim
    520-403-9002
    Attached Files Attached Files
    Jim Short
    www.tahlinc.com
    Sep 2004
    209
    That's what mine looks like, except mine is a lot dirtier... I guess the only question is if there was more than one model that used the same enclosure.
    Mine came out of a Roku Fanuc 6MB milling machine. Do you have a number on the PCB?
    Chris Kirchen
    Jun 2003
    70
    I will check tomorrow.
    Jim Short
    www.tahlinc.com
    Jun 2003
    70
    I do not have that board.
    Sorry.
    Jim Short
    www.tahlinc.com
    Aug 2006
    25
    We should have this in stock if you still need it. Please contact me if you are interested.
    Aug 2010
    24
    Magnetic sensor
    Hi
    I am also looking fanuc magnetic sensor for my kitamura mycenter2. This is for spindle orientation. The part number is A57L-0001-0037. Pl inform where i can buy this part (new or second hand).
    Jun 2003
    70
    Look on ebay
    Jim Short
    www.tahlinc.com
  1. Hall sensor connection
    By rainman in forum CNC Machine Related Electronics
    Last Post: 01-09-2008, 02:13 PM
  2. Vibration sensor
    By efrag in forum Mach Wizards, Macros, & Addons
    Last Post: 12-27-2007, 05:08 PM
  3. magnetic sensor
    By keithmech in forum CNC Machine Related Electronics
    Last Post: 07-29-2007, 12:04 AM
  4. non ARC height sensor
    By sunmix in forum CNC Machine Related Electronics
    Last Post: 11-05-2006, 06:51 PM
  5. Optical sensor...
    By aghobby in forum DIY CNC Router Table Machines
    Last Post: 09-08-2004, 05:17 PM
